Maytag M3DH30B2A Dehumidifier Logo
Joe Kohler Posted on Mar 03, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Compressor is not working
I turned my Dehumidifier off for the season and when I turned it back on today the compressor is not kicking in. Thanks for any help
  • rdrt Apr 23, 2008
    My Dehumidifier Model # M7DH65B2A; S.# DU186587096Y; DOP 7/22/06
    Problem: Runs and runs and does nothing oviously the compressor is not kicking in. I have shut off unplug restarted and does the same thing. My e-mail is [email protected] . I see I have a 5 year warranty.
A
Anonymous
Matag M3DH3DB2A Dehumidifier --
Lost bracket that holds float switch in place.
need new bracket. thanks.
[email protected]
A
Anonymous
Same problem with mine. Just pulled the thing apart ...and they were nice enough to have a schematic right behind the water bucket. In my case I found the defrost switch was open. If you pull the back off it's located in the lower right corner clipped to the compressor pipe and covered with a black insulating putty. It has two large red wires coming out of it as well, quite obvious. I unclipped mine and tapped it a few times and it closed up - so now the compressor will come on ...but I'd like to get a known good one in there. I just found this site was I was trying to find the part. If anyone knows where to get one please post! PN: 37TA32 501624 F57-20F J0332 Thanks! - Pat
Anonymous
Level 3:
  • Master 944 Answers
  • Posted on Mar 07, 2007
Anonymous
Master
Level 3:
Answers
944
Questions
Helped
786562
Points
2417
Try gently tapping the compressor a few times -use a wooden stick or similar to avoid damage -sometimes that is all that's needed. There are however many other possible reasons for a compressor not to start - most have their own fuse/controller assembly (sometimes this is very obvious inside the case, often a car spade type fuse which is worth checking visually), and there are cut-outs that will stop the compressor if it is low on gas, although usually it will start first for a few seconds if this is the case. Sorry, but the (www.maytagair.com) website is down at the moment, but try it again later and you should find their troubleshooting and support is good. Hope this helps :)
Have Danby dehumidifier, turned on first time this season,fan & all displays worked fine, but compressor never went on. Removed back panel & compressor is very hot.
Be careful. i do not know. set at highest setting and let it run. while running, reduce setting to the lowest over a few minutes. at a lower setting you should be able to tell that the compressor has started. run it for 5 minutes, then
unplug your machine. next, feel the cooling coils to see if they are very cold. if they are not cold, your unit needs to be serviced.
1helpful
How do I determine reason that my Danby Dehumidifier isn't cycling on to compressor for more than 3-4 seconds at a time? Fan always runs but compressor only kicks in for 3-4 seconds then back off.
I would say low on gas or bad switch/thermostat.
The compressor probably has a shutoff for low freon. You would need a set of gauges to check for that.
Bad thermostat? You'd need a ohm meter.
User error? What kinda settings or controls do you have on the control panel?
There was a recall on these in 2014 for catching on fire.
Gree Reannounces Dehumidifier Recall Due to Serious Fire and Burn Hazards...
Hi... my dehumidifier compressor will not turn on, the fan runs fine and the time 2 hr/4hr cycles work, but the compressor wont kick on, the filter is clean and the unit is no more than 2 yrs old. Any...
Sounds like the compressor is inoperative. Most, if not all new units have no means of recharging the freon if it leaks out. If the coils are not cooling, the compressor is not operating and the unit will not dehumidify.
Re: Kenmore 54501 dehumidifier. Both fan and compressor sound as though they are turning on, but no water is evaporated into the water bucket. The unit had always operated properly during past seasons,...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
2helpful
My Santa Fe compact dehumidifier in my crawlspace makes a noise (not a smooth humming sound but more of a harsh vibrating sound) when it is not dehumidifying. I can turn the knob to the dryest setting and...
The black cylinder is the compressor. It sounds like your unit is cycling the compressor for some reason. If the compressor starts, runs fine, and removes water when you set the humidity control to the driest setting the compressor is probably OK and the problem may be with the humidity control causing the dehumidifier to "short cycle" for some reason. You may need to change the humidity control or relocate the dehumidifier in your crawl space.
If the compressor attempts to start, and then sits quiet for 10 minutes, and then attempts to start again, you have a problem with the dehumidifier. There are a few things that can cause this problem:
Low refrigerant charge
Bad compressor capacitor
Bad compressor overload
Plugged capillary tube or broken expansion valve
are the common causes of this behavior. If you suspect one of these problems, call the factory service department at 1-800-533-7533 for help.
Good luck with your dehumidiifer.
Doesn't dehumidify
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Lg LHD30 dehumidifier not producing water; fan and compressor both seem to be working
there may be no moisture to collect in the air. if you turn up the dial and the compressor kicks in, all is fine
Kenmore 54701 (70 pt) dehumidifier is not prerforming properly
could be a bad humidistat or a bad PTC relay on the compressor, check for voltage going to compressor, and check neutral continuity, if there is both then you have a bad compressor, check warranty on comp replacement, if no voltage then the humidistat is probably bad
Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Top Maytag Dehumidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
goneforever.
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
