Question about LG 42PX4DV 42 in. EDTV-Ready Plasma Television
Lg42pc10 My nephew was playing with the remote & some how seems to done something! It just has 'not programmed' bouncing round the screen! How do i program it? The tv has built in freeview which i use!
4 Suggested Answers
6ya staff
SOURCE:
domotek
Tommy
  • 591 Answers
SOURCE: TV remote won't work. Batteries are OK. LG
Is it the original remote of the TV? or an "all in one" type???, if it's the original remote you don't need programming, if the batteries are fresh and correctly installed, than check the InfraRed output with the help of a camera... The human eye cannot see IfraRed but cameras do... so point the remote to anny camera (with video capabilities) and press the buttons on the remote, if you see the IR Lights flashing through the camera, than the remote is working, if not than the remote is dead, check for cold joint solders inside or buy an all in one remote...
Posted on Aug 09, 2011
Rocky
  • 302 Answers
SOURCE: The screen size on my tv needs adjusting . How do I do this thro' mt Sky remote?
The screen size is also called the aspect of the TV. look in your menu for aspect ratio.
Posted on Dec 16, 2011
gopakumarg43
  • 76177 Answers
SOURCE: need code and instructions for programming a remote for an LG flat screen tv
Visit this site "Electro-help". Type in the site name in yahoo search. It has all details you want. Codes, setup proceedings etc:- Pull up older posts there.
Posted on Jun 10, 2012
Samsung DVD Player remote buttons activate Samsung TV settings
To do a reset of the remote control follow the instructions below.
1. Remove the batteries from the remote control.
2. Hold down the Power button for a full minute.
3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below
1. Press the BD button on the remote control then press Home. This should bring up the home screen.
2. On the Homescreen, choose AllShare Play and press the Enter Button.
3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''.
4. Now the titles of the recorded programs will appear.
5. Press the Tools on the remote control and select ''Delete'' from the side menu.
6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control.
7. Select ''Delete'' from the side menu then confirm deletion.
To try and resolve this issue, please reset the remote control. To do so, please refer to the instructions below: 1. Remove the batteries from the remote control. 2. Hold down the Power button for a full minute. 3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below: 1. Press the BD button on the remote control then press Home. This should bring up the home screen. 2. On the Homescreen, choose AllShare Play and press the Enter Button. 3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''. 4. Now the titles of the recorded programs will appear. 5. Press the Tools on the remote control and select ''Delete'' from the side menu. 6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control. 7. Select ''Delete'' from the side menu then confirm deletion.
Jun 27, 2017 | Samsung LA40A550 40 in. HD-Ready LCD TV
Ustvnow dvr tv shows unable to watch recorded shows when press play without causing tv screen to flicker twice and not able to watch tv program
It appears it is not your fault. I contacted ustvnow and they said they are "working on it" but currently the DVR service is not available on roku. If you find an answer elsewhere, I'd love to hear it
Dec 01, 2012 | Televison & Video
Bouncing balls won't load on. Facebook
Call Zynga's Phone#: 800-762-2530
How to reach a live person: Dial 3 when recording begins
Aug 15, 2012 | Apple iPad 32 GB 3G Tablet PC
Genie g3t-r remote seems like it 's programmed but doesn't open door. led's suggest it was programmed.
1) test the batteries 2) rETIGHT THE spring contact batteries 3) Resolder wires for contact batteries, see if there are some wires missing. 4) Try again with the codes.
go www. fitness.manualsonline.com get the code , and reset again.
Otherwise the remote control you must go to the repair shop.
God bless you
May 09, 2012 | Genie Company IntelliCode GICT390-1BL...
Tftv826hd starting method
More likely he touch the input button on the remote and the TV is set to receive from a source that you don't have.
Mar 25, 2012 | Televison & Video
My exprssion mini split a/c has switched off and only goes on if you use the override switch inside the unit and will not operate with the remote any longer - it went off after my nephew put it on and kept...
The remotes for the mini-splits send very complex digital codes each time you press a button. If the batteries are not working at nominal voltage the remote will not send the signal correctly even though the screen seems to work fine. Try switching out the batteries.
Sep 04, 2011 | Carrier 38BRC036 Air Conditioner
Something got zapped in an electrical storm the other day. We lost our upscaling DVD completely, but the Dish 625 receiver still works... but not so well. Our things are still on the DVR, but they play...
Hi my nameis Mike Houston of DISH Network and I see that something got zapped in an electricalstorm. If there is an issue with the DVR playing back choppy and the channelsare hard to change there are something's that can be done to resolve thisissue. Press the buttons of Menu-6-1-1 and then select Check Switch and pressTest, after all test complete select done two times and select Cancel threetimes and the receiver will reacquire the signal and download the Program Guideand your programming will come back. After your picture comes back please trythe functions that were having the issue(s). And if the issue still persistsplease e-mail me at michael.houston@dishnetwork.com.
Aug 03, 2011 | DISH Network DVR-625 DTV Receiver /...
I need a replacement 27MHz remote control for a Playskool Tonka Bounce Back Racer model #09995. This model has been discontinued. Would another 27MHz remote, with forward & reverse control features...
Yes! The FastLane brand works. I thought my bounce back was a loss because the remote doesn't work until my older daughter played with her remote control car in the same room. The Tonka Bounce Back responded very well to the FastLane remote. And fortunately, FastLane is pretty inexpensive. Good Luck!
Jul 10, 2011 | Playskool Tonka Bounce Back Racer Remote...
Sylvania (SRD3900) DVD Player / VCR Combo i can't seem to plug in the red/white/yellow cables into the right places directly to my old toshiba tv to play either tapes or dvds. can you instruct me? thanks.
Greetings - It's very simple so I'll show you how and then I think it may be another problem (nothing broken).
You need to plug the corresponding color cables into to outputs on your player I've circled above and then into the corresponding inputs on the TV. You've probably done this correctly.
PLUS - You have to, using the remote for the player, set the source to either DVD or VCR and then you have to, finally, on your TV set the input (with the remote) to what is called probably VIDEO or VIDEO1. If there is still nothing on the screen keep (with the DVD or Tape playing) hitting the TV remote input button until you see an image or you've come around to where you started.
Unless something is broken (unlikely) you should be able to watch DVD's or Tapes depending on what input you select on the player.
If it's not working you've somehow missed a step or the Video input on the TV is called something else. If that happens come back here and give the player AND TV brand/model info and someone will be able resolve your problem.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 21, 2011 | Sylvania (SRDD495) DVD Player/VCR
Picture bounces up and down
All new VCR's are auto tracking however, you should be able to manually track it using your remote, or there are a few reasons that the auto track can fail, the tape may have worn or ragged edges which means that the control head cannot get a clean reading, the control head may itself need cleaning or the tape path requires adjustments, adjusting the guides really needs to be done by a technician as a reference tape is used, or that the heads are low and a good video signal cannot be obtained to gain a reference point....Phil
Dec 15, 2008 | Sylvania 6240VE VHS/S-VHS playback VCR
LG 42PX4DV 42 in. EDTV-Ready Plasma Television Logo
69 people viewed this question
Ekse
RONALD CARTER JR
