To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
You need to make sure the machine is in Copy Mode when you hit
# * C *
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Your machine has automatic fuser pressure control. It's supposed to release pressure when you shut it down, and reset it on startup. This is done by a combo of a motor & gear on the machine and a gear on the fuser. Somehow this has gotten reversed or jammed. you need to take the fuser out and make sure the gear is in the right position and that no rods are in the way (there's a cleaning rod resting on your lower fuser roller, often this will tuck under its' mounting rode and wedge)
H4-00 means thst the copier isn't warming up quickly enough. Try this code to reset it. Press the following buttons in this order: #, interupt, C, interupt, 1, 4 . machine will say sim 14 trouble clear are you sure. Press the OK button. This should reboot the copier. Most likely the machine is in need of a heater lamp in the fuser unit.
Yes H5-01 is when it jams in the fuser 5 times in a row, check the fuser section for a jam, the paper jams up in there and does't trigger any sensors, once you have confirmed that its clear reset with sim code 14
Sharp mx 1810u f2-40 error code
