Question about Motorola Mobility MBP16 Digital Baby Monitor
NOT LINKED displayed on parents unit - Motorola Mobility MBP16 Digital Baby Monitor
    New Friend:
Go into the settings on the baby unit and hit reset. Then, turn both units off and back on and they should link up.
Posted on Mar 29, 2013
  • khalid
    khalid Apr 27, 2014
    i couldnt work out how the reset on the baby unit. but i did reset on the parent unit and its still not linking..how do i reset on baby unit?
  • John Breault Oct 27, 2019
    i can't even get it to turn on just red light on
6ya staff
SOURCE:
I forgot childlock password in panasonic tv c400
http://eng.faq.panasonic.com/app/answers/detail/a_id/10865/~/how-do-i-reset-the-pin-code-for-parental-control-use-if-i-have-forgotten-it%3F
Online chat for support.
Instructions show above:
How do I reset the PIN code for parental control use if I have forgotten it? Please follow the steps below:-
  • Power the unit on.
  • Open the unit's drawer.
  • Select the BD drive with the Drive Select button.
  • Press and hold the REC and PLAY buttons on the front of the unit together for 5 seconds until the display shows INIT.
  • Confirm that the front display shows 'INIT'.
  • The parental PIN code has now been reset to the default code of '0000'.
Jul 25, 2018 | Panasonic Televison & Video
Mbp16: parent monitors wont link to baby monitor
Hi Matt,
You should contact Baby Monitor support specialists for further assistance.
Http://www.Motorolacordless.us
Emilio
Motorola Support.
Jan 13, 2013 | Motorola Mobility Mbp16 Digital Audio...
Although my bt baby monitor 150 units are fully charged and within range they still will not link up. They have worked perfectly until yesterday. I have tried doing a factory reset & taking the...
I had the same problem, have just spoken to BT (helpline is 0808 1006554) and they advised this is how you re-link the base and parent unit.
1. Switch both units off
2. On the base unit press volume up (+) while turning on the unit. The word "registration" should appear on the display.
3. Then on the parent unit, press the power on and then as soon as all the lights come on, take your finger off the power button and press the volume up (^). The word "registration" should appear on the display and then the units should link.
It's a bit of a fiddle getting the parent unit to re-register and they both need to say "registration" at the same time, but we got it after several attempts, and now they are working fine.
Apr 16, 2011 | Toys
Cant see the video the screen just goes blue with a circle picture around the monitor
This indicates the camera is not linked to the parent unit. Hold down the button on the camera until the light around the on/off switch flashes green. It is now linked to the parent unit.
Apr 14, 2011 | Safety 1st Digital Video Monitor
Angle care wont connect to the base
Manuals: http://www.angelcare-monitor.com/Canada/en/help
Had same problem - here's what worked for AC401 (from manual):
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT: If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and press and hold the MENU button ,the "out of range"indicator will flash and you will hear a beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect. The Tic light flashes.This normally happens within a few seconds and you will hear a bleep to confirm it. If successful, the parents unit display will first show the channel of transmission (C1 to C8), which will be replaced by the room temperature and icons for all activated functions.
Dec 20, 2009 | Angelcare 2009 Movement Sensor Baby...
My parent unit wont do anything, it just flashes with the nursery unit simble and i can not access the menu.
Manuals here: http://www.angelcare-monitor.com/Canada/en/help#tabs-2
Oct 16, 2009 | Angelcare Deluxe Movement Sensor & Sound...
The parent unit does not recognize that the nursery unit is on. all the correct lights are displayed on the nursery unit for normal function, but the parent unit display indicates that the nursery unit is...
Sounds like the units need to be paired. Start with all units off. Then turn on one of the parent units. Press and hold the menu button until it beeps. Quickly turn on the nursery unit and press and hold the button on the nursery unit that has the parent unit icon below it. After a couple of seconds the units will pair. Repeat this process with the other parent unit.
Oct 10, 2009 | Bebesounds Ac401 2p Angelcare Deluxe...
My parent unit is not working. All it does is flash when it's supposed to show me the pendulum swinging, room temp etc. I have forgotten how to reset it. Help please
Oct 02, 2009 | Angelcare Deluxe Movement Sensor & Sound...
I need instruction manual for a Fisher Price Child locator
71573 Child Locator Years Made: Fisher-Price Toy Department
Department 6:
Non-Toys & Accessories 1999+
Description: The Fisher-Price Child Locator is an ingenious two-piece device that allows parents to quickly locate their child. One unit is worn by the child, and the other unit is worn or held by parents. The units are continuously linked by communication signals, and an alarm will sound if the signals are severed due to distance or interference, or if the child's unit is removed. When parent press the button on their locator, the child's unit will beep so parents can locate the sound. Designed for parent of children ages 2 to 6 years old. Requires 6 "AAA" alkaline batteries (not included). Accessories: Two-piece device, one piece is worn by the child, and the other piece is held or worn by the parent:
  • FPT14246 - Child locator.
  • FPT14247 - Parent monitor.
Variations: None. Other Information:
  • FP71573SET1999 - complete set in original box. WFL: 07-AG-21-4-A
Jan 03, 2009 | Toys
Motorola Mobility MBP16 Digital Baby Monitor Logo
2,378 people viewed this question
Top Motorola Mobility Baby Gear Experts
Dorel UK
Dorel UK
Marvin
Marvin
john h
Are you a Motorola Mobility Baby Gear Expert? Answer questions, earn points and help others
