My hotpoint washing machine (w860? i think) is making a really loud clicking noise, seems to come from the powder drawer area. and now has displayed f-05? any ideas?
thanks
F05 is a drainage problem, ther may be something stuck in your pump.
its in the back of the machine in the corner. take the side hose off and unclip the pump from machine and look in to see the propellor may have foriegn object in.
Sounds like it could be relatively expensive to put right.
Personally, I think you would be better in investing in a new washer, more so in view of the fact that is 7 years old.
There are numerous possibilities for the symptoms you describe.
Hope this helps you to come to a decision.
Yes, this washer does have a heating element.
Make sure there is a good water pressure at the inlet valve/s,
or the powder will not dispense.
Make sure there is no blockage or obstruction in the drawer, \also make sure you have the powader in the correct compartment.
Hope this helps.
with experience, put powder in the first, softner in the middle second, pre wash in the third, but with that model i find its always best to use a liquid or gel direct into the machine, it makes the life of the machine last longer, also stops any build up residue
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
