One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive Test all power and data leads that attach to your hard drive IDE,SATA the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even something as small as an electrical fan and its lead can cause you problems computers need all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard hope this helps
SOURCE: touch pad won't respond frozen
Did it work before? What was changed since? If it did, does a mouse work? If so, goto system and uninstall the pad, reconnect the pad and reboot. Driver may have been corrupted.
SOURCE: Toshiba equium p200d-139d screen goin blank
Well, you can try this....
In safe mode, go to start->run, type in msconfig, and the system configuration window will come up.
SOURCE: my loptop doesnt start-toshiba equium a100-306
Try reinstall the OS. or press F5 or F8 when boots AND LOGIN TO SAFEMODE AND DO SYSTEM RESTORE. if are not able to go to safemode, then press del when boots and getinto the bios and check the bootable device is harddisk
SOURCE: Toshiba P200D-139 xpsp2 device drivers
sp2 ( service pack 2, available free on microsoft website ) contains a bundle of updates for xp including driver updates.
SOURCE: DVD ROM won't read disks . Toshiba Equium
YOU SHOULD GO THO TOSHIBA SERVICE CENTER AND YOU CAN REPAIR IT ON ANY COMPUTER SHOP
