BLOCKED DRAIN TUBE BUT CANT FIGURE OUT HOW TO ACCESS, CANT GET BOTTOM DRAWER OFF
You pull the drawers out as far as they go then lif up and again pull straight out. That can be found on page 15-16 in the user manual found HERE If you need help I will be here just ask, Thanks Sea Breeze
Get Adobe Acrobat Reader
Try that link again the last link was cut offhttp://appliance911seabreeze.com/ABB2224...
Below is a link to more instructions if that was not enoughhttp://appliance911seabreeze.com/ABB2224...
SOURCE: Amana SRD522
sounds like water line is blocked with frozen ice. have a technician clean the line and check the icemaker and water line for any kinks.
SOURCE: Amana bottom drawer fridge/freezer combo
hi. thanks for the question . it sounds like you have a compressor problem . wich is under warranty from amana. great news get in touch with amana thanks the appliance doc
SOURCE: Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
SOURCE: I have an amana abb2522feb bottom freezer
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Check out these tips...they can help you figure out whats going wrong with your
refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
