Question about Mongoose Sycamore Women's Comfort Bicycle
How do I avoid hitting the front tire with my foot? The distance doesn't seem big enough.
  • 843 Answers
Unlike stirrups on a horse saddle, where you would hook your heel up against it, pedalling is best done with the ball of your foot. This allows you to use your entire leg including your ankle to provide the power. This might seem a bit uncomfortable at first, but you will get used to it very quickly, since it will tire you less and is more like the natural motion of walking. Placing your foot too far forward on the pedal makes pedalling more like walking on your heels.
Posted on Jul 06, 2012
6ya staff
SOURCE:
President club car golf cart front tires wear out every 3 months.
Maybe your front end alignment is off?
Measure the distance across the front of the front wheels and across the rear of the front wheels.
On this cart the measurements should be almost exactly the same.
Measure carefully as the measurement needs to be exact.
If the measurements are not the same,adjust one or both tierods to make the distance between the front and rear of the front wheels the same.
TIP:AVOID sharp turns on pavement which will also accelerate tire wear.
Apr 08, 2017 | Cars & Trucks
Barbie power wheel just spins doesn't move
some people stud the tires with screws, or rubber traction bands can be purchased, or just put rubber bands on the tires for indoor use
May 15, 2017 | Fisher Price Power Wheels Barbie Jeep
Ford truck bounces hitting a bump
Have you cked the bushing lower and upper
Mar 03, 2013 | Cars & Trucks
When a strut is worn,what are symptons? How can one diagnose it? KIA Sephia 1998?..
some times you will get a bouncing in wheel ,nose dive in front end when stopping or hard breaking, did you try jacking up car so wheel is just off ground ,put a bar under tire and lift up observe wheel movement ,then do other wheels , if it is a strut the wheel will move up and down freely , look for fluid leaking around strut body ,5000 miles is not much of a factor things do break.the other is get the front end off the ground both wheels,SAFELY !!!!!! WITH THE CAR SHUT OFF WHEELS BLOCKED, have one person turn wheel while you observe it , look for anything wrong grab the wheel and try to move left to right (a small ) motion observe what happens ,is there wiggle ? with out moving steering wheel. if not sure of any of these ,PLEASE take it to a mechanic .hope this helps good luck. Woody
Apr 19, 2017 | 1998 Kia Sephia
Front tire won't come off
Sit on your but and kick the tire with both feet. The tire is stuck. Some tire repairmen use a large sludge hammer and hit the tire,don't hit the rim.
Sep 01, 2012 | 1992 Ford Festiva
My foot pedal keeps hitting the front tire on my mongoose sycamore bike
By the way, you'll also never catch your toe on the ground (which can cause a very painful mishap) if you pedal with the ball of your foot.
Jul 05, 2012 | Mongoose Sycamore Women's Comfort Bicycle
My 2009 Nightster tire pressure - I'm seeing/hearing/reading different suggestions. I single ride. right now Front tire is 31, rear tire is 40, is this exceptable. Thanks
Yes, this is acceptable. I prefer to set the front tire at 30 and the rear tire at 36 when riding single. It's a matter of ride quality preference. As long as the tires are inflated enough to prevent excessive flexing of the side walls, you are safe. By lowering the air pressure, you get a bit better traction as your tire's "foot print" is a bit larger but it doesn't handle quite as quickly either.
Good Luck
Steve
Jun 09, 2011 | 2011 Harley Davidson XL 1200N Nightster
We have the lugs off the front tires of our 06 ford explorer and the tires won't come offf. What is the problem?
they can get stuck on the hub. just kick it or hit the tire with a big hammer and it will come loose.
Mar 25, 2011 | 2006 Ford Explorer
The front right tire hit the crub to avoid and accident it bent the sway bar which i replaced but the tire is at a angle and is wearing out the outside of the tire. what else would the problem be?
Your control arm or tie rods may be bent. If you hit a curb hard enough to bend the sway bar other things are probably bent also. Best bet is to take it to a front end shop and have it checked don't just start replacing parts. The car will need to be realigned when parts are replaced.
Nov 23, 2009 | 2002 GMC Envoy
Back tire
often times the inner hub of the rim seizes up in the spindle. use the wd40 on the studs and the rim hub and let sit for an hour then your going to have to use you foot to kick the tir on the top and the bottom of the tire untill it works loose. also have somehelp you by using a big sledge hammer to hit the back side as you hit from the front of the tire this will work quite well. in no time tyhe tire and rim will come off . then use a anti seize on the spindle hub not on the studs when you replace the tire.
Apr 18, 2009 | 2002 Oldsmobile Bravada
Mongoose Sycamore Women's Comfort Bicycle Logo
121 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
JohnLong
Pierre Laplante
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
