Good morning or evening, depending on your location. :) Hey, I need to get some handles for a new builtin-refrigerator with a cabinet front. I like the one on the current Uline beverage centers . . . contemporary looking, stainless steel, straight handle without any curve except the overall rod-like handle, and about 30-inches in total length.
Please tell me the actual overall length and distance between center?
Frigidaire Gallery & Professional appliances put a micro-coating over their brushed stainless to help prevent smudges and fingerprinting. However, if this coating has begun to peel off there isn't much you can do about it. You can order a new door for it for around $250-$400 depending on the door. Very rare for this to happen. If was a common problem, they wouldn't make it like this.
most the handles will inter change . you will need the model # of the other frig in order to get the ones you like . but keep in mind they are not inexpensive . I looked up one of these pt # 2316868 stainless handle and are sittind down! they are $ 101.93 each . . and you need 3 .. hope this helps mm feed back pls
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
you should check out www.applianceart.com, they have vinyl and magnetic solutions that can cover your appliance in a new color or pattern. They even have a stainless steel option for refrigerators too.
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.) Good luck!
you should have trim below and above the handle if not then and its a stainless steel door then there is small round opening on the side of the handle you'll need allen wrenches once you loosen the allen the handle slides up or down then you will be able to tighten the stud post screw then reverse the mounting -----------------be cautious of scratching the stainless steel door when removing the handles
mine was the handle was loose on the door not the coil in the stainless problem . i will try and figure it out my self i will not pay to have the handle tighten
