SOURCE: freezer wall ices up, fridge not staying cool
Is it ice in the freezer or frost? snow like.. big difference in problems
SOURCE: Kenmore Model # 596.735032.. Fridge is cool, Freezer is not freezing
After pulling the fridge away from the wall and removing the lower right hand panel I noticed that the compressor (big round black ball with copper tubing) was not turning on. I also noticed that there was a ticking or popping sound comming from it every couple of minutes or so. After doing some research online in numerouse forums I decided to try and replace the overheat relay that is attached to the compressor. It only took maybie five minutes at most to change it and the compressor is now working with nice cold air comming into the fridge and freezer. Hope this helps someone else with the same problem.
SOURCE: Refrigerator freezes up
PLEASE DISREGUARD GUEST FIXYA SOLUTION,FREEZER PROBLEM PROCEDURE IF NOT DEGITAL,FIRST CHECK IF ICE ON BACK FREEZER WALL. STEPS-FIND DEFROST TIMER,BOTTOM FRONT ,BOTTOM BACK, INSIDE FRIG.ON CONSOLE,LISTEN TO SEE IF FAN IS RUNNING IF SO TURN THE DEFROST TIMER CLOCKWISE TILL YOU HEAR A CLICK SEE IF FAN TURNED OFF IF SO YOUR FREEZER IS IN DEFROST,FREEZER WILL COME OUT OF DEFROST IN 20-30 MINUTES IF IT DOES AND THE FAN COMES ON YOU HAVE ELIMINATED DEFROST TIMER&FAN,NEXT REMOVE BACK PANEL TO FREEZER IF THERE IS ICE FORMING REMOVE BOTH LEADS TO HEAT AND CHECK WITH VOLT METER ON OMES,IF YOU GET ANY READING THE HEATER IS GOOD,IF NO READING REPLACE HEATER AND CLIPON TEMINATOR,IF HEATER IS GOOD DEFROST COILS WITH HAIR DRYER TOP TO BOTTOM AND THIS WILL ALSO CLEAR THE DRAIN,IF EVERYTHING CHECK OUT GOOD DEFROST TIMER ,FAN ,HEATER, DRAIN, YOU NEED ONLY TO REPLACE THE LITTLE ROUND CLIP ON TERMANATOR,LET ME KNOW-MIKE
SOURCE: KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
first off unplug ref and melt the ice with a blow dryer.then check your defrost circuit,it is easier to check with the ice gone.
The freezer will stay cold because a small
amount of cold air will be forced through the frost but that will not
be enough to make it up to the refrigerator portion. You can defrost
the unit by removing the metal panel and allowing the frost to melt.
Careful use of a hairdryer can speed up this process. This will likely
be a temporary fix. The root cause of excessive frost can be caused by
a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar
bill at several points around the door, both on the freezer and
refidgerator door. If you can pull the bill out with no resistance, the
door is not making a good seal. Inspect the seal and make sure there
isn't anything stopping the door from closing such as food, or a shelf
not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The
defrost system has three main parts, the defrost heater, thermostat,
and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually
starting the defrost cycle. Let me know if you would like this
procedure.
