I purchased the wiring from battery to gearboxes but need to know if I did it right because I am getting no result. I already checked the battery and it is fine. This is the older model. Before I did this it did run in 2nd gear but no first and no reverse. Thanks,Paula
SOURCE: peg perego gator grinding noise?
The Peg Perego Gearbox is the item that would make a clicking noise or grinding noise.
There are two different types.
One is a cross shape and another is a pentagon shape.
If you contact the folks at http://www.shopjandl.com/ they will be able to tell you what type you need. I get all my parts from them because they help me figure the problems out.
Hope this helps
SOURCE: i need a new batery charger for my peg perego
I bought my Peg Perego Charger at
http://www.shopjandl.com/mecb0034.html
They fit the 12 volt blue batteries for Peg Perego.
Hope this helps
SOURCE: Our Peg Perego Gator has a brand new battery yet
I would check to see if both wheels are spinning in high.
If only one spins, then it may have a loose connection on one of the motors.
You can also get the specific peg perego gator switches from the guys at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
They also have a phone number that you can call them to explain theproblem with the vehicle, they seem to know a lot about them.
Hope this helps.
SOURCE: Peg Perego Gator won't run.
look for a bad conection on the wires follow them from the battery back to the point of origin
SOURCE: bought a yellow 700 Peg Perego Polaris, 12 volt,
THERE MAY BE A SAFETY SWITCH UNDERNEATH IT SOME WHERE YOU MAY HAVE TO TURN OFF.
SHERRI
