SOURCE: Invicta watch has loud self winding
Sorry for your Rolex....
In any case you will not be able to to repair watch yourself as it takes skilled man and special tools to do the job.
It is NOT common that the winding rotor is making a noticeable noise, unless you bought second hand watch.
1st cause can be that the rotor fixing screw is loosened and the rotor is touching caseback whilst in move. Then you are the lucky one as the only thing to do is to tighten it properly.
2nd cause can be that the ball bearing is too worn, bridge screwws are loose, rotor axis worn and so on and so on. In this case you may need some part replacement and much more complicated work must be done. As the outcome it will take more time to repair and you will pay more money.
Regards
Arthur
