The machine does take in water when starting but it wont wash after closing lid.
SOURCE: Washing Machine GE Profile/prodigy
you have a dry on your programmer you should not do this your self i would go down and see your local second hand shop who can help you with is they normally do jobs like that appliance shop is the best place to go it will be cheap
SOURCE: MY BEKO 1613S WONT WASH MY CLOTHES
Quite a common problem. The least common is the actual failure of the timer itself. It is much more commonly caused by the failure of the heater, water valve, pump, a broken wire or even a blockage in the pressure system or waste system.
SOURCE: want start unless you slam lid or push start knob in and out
HI, Check and see if the door hinge screws are tight. Sometimes the hinge loosens and the lid switch will not activet properly. It the lid is tight, you might have a lid switch going bad. The lid switch is located under the control panel. There is a screw in each corner of the control panel in the back side. Loosen these screws and lift the control panel up and it will rest on the hinges.
Ths lid switch is to the left and should have three wire to it. Parts# 8318084
I hope this helps you. If I can assist you further or you need a place to order the lid swtich, please give my web site a chance at www.whirlpoolpartssurplus.com
Thanks
Vic
SOURCE: my kenmore 90 series washing machine fills with
Remove the water pump and inspect it for a lodged garment blocking the motor from turning.
SOURCE: My Sears 500 washing machine stops in middle of wash cycle.
timer problem or maybe the lid switch is going bad. Im curious if the motor is getting hot and shutting down... go to whirlpoolpartssurplus.com call .. ask for mark
