When the gas bottle is screwed in the gas starts to leak somewhere out of the knob area. The seal of the gas bottle doesn't leak - it's leaking from somewhere else.
SOURCE: Hi I have 2 burner
hi,
1 GRATE Assembly
2 Burner Assembly
3 REGULATOR Assembly
4 VALVE WHEEL
5 IGNITER KNOB & SCREW
1)Blow air into the valve wheel connections so the blockages will be cleared.
2)Remove the burners and clean it perfectly.Dry the
burners using hair dryer and remove the parts and clean everything
perfectly.Burners will be screwed with two screws.
3)Knob switch could be also could be problem,small dust
particles will block the flow of current to bypass switch.
4)In
some Coleman 2 Burner Propane Stove models the Ignitors
are prone to defective.They go bad when use for long time.Replace it
if it
is defective ignitors cost very less.Remove the screws to change the
ignitor.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
