Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
or you might not have the correct drivers
http://download.biostar.com.tw/upload/Driver/Chipset/Intel/VGA/EagleLake/VistaWin7_32/win7.exe
http://download.biostar.com.tw/upload/Driver/Chipset/Intel/VGA/EagleLake/VistaWin7_64/WinVista7_64.exe
http://download.biostar.com.tw/upload/Driver/Chipset/Intel/VGA/EagleLake/XP32/Setup.exe
http://download.biostar.com.tw/upload/Driver/Chipset/Intel/VGA/EagleLake/XP64/Setup.exe
hope this helps
SOURCE: Biostar GF 7100-M7 windows xp trouble
Do you see any text at all when booting up? If so, try pressing F8 on reboot to get to the Windows Boot menu. It's not real apparent when you are supposed to do this, so once the system gets past the initial Power on Self Test, start tapping it. Select Safe Mode and see if your display loads. Set your video settings to something safe and simple like 1024 x 768. Reboot to normal Windows and begin bumping your video settings up from there until you get them where you want them.
SOURCE: On windows xp 64bit no sound Biostar motherboard TA790GX A2+
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
aafgsgh1
SOURCE: After installing new Biostar Motherboard
you may need to set your bios setting and make sure the choose the proper boot device, first boot device is cd rom and second boot device ( hard disk ) and save it. After then repaire the window with window cd.
SOURCE: No audio from Biostar g31-m7 te motherboard
check bios setting and v erify that audio codec(AZALIA) is turned on
SOURCE: need 64 bit usb drivers for my motherboard - a Biostar G41-m7
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=421
try this one
