I have a Lg TV connected to a sky box and dish but I do not have sky any more, my telly will crackle every so often make a noise then I get no sound, we switch the tele and sky box of then wait for the noise to come back on the screen then we can get the sound back. Thank You
SOURCE: LG 42LC2D-EC NO SOUND ON HDMI
your setting for source of the audio is probably defaulted back to original setting in receiver. reassign audio input and problem may go away. it sounds like its not in the tv. i assume you have a receiver and are not trying to listen with speakers in tv. is this correct? if you are not using an amplifier, you may need to go to the tv menu to make sure the audio source is selected as the hdmi input. should take a bit to read thru the manual, but it ought to show you how to accomplish the correct settings.
let me know if it does not.
good luck
mark
SOURCE: Crackling Sound from Speakers
check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
SOURCE: LG t.v is saying no signal on the screen for the cable box and a dvd player.
if the sky box is not registered with your viewing card, it will not show. if you want to check that the monitor is working plug in a dvd to make sure its not the monitor that is at fault.
SOURCE: LG 42PG6010 sky code
this might work
0206
if not check here http://www.satcure.co.uk/tech/digicode2.htm#contrib
