When I turned on the TV, the front LED flashes red 7 times. Than remove back panel, i see the power supply led flashes green three times. (that's mean VSCAN error)!
Please Help - who know how to fix that!!
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Have the same problem Phillips cust service was no help just said that it needs service.
I am having the same problem myself, on my Philips 32 in LCD Widescreen. It wasn't showing any issues, prior to the picture and sound going out. I turned off the tv and unplugged it from the wall for about an hour. When I turned it back on I still received the flashing red LED light in 7 flahing intervals. Any suggestions would be appreciated
same as above
