Briggs and stratton 60.5 platinum plus
SOURCE: Pressure washer with no pressure
Are you priming the water lines before you switch on the power?
i.e. with power OFF, hook up hose and turn hose on (doesn't need to have much hose pressure), then take your spray gun or attachment and pull the trigger and allow water to flow through the system (at hose pressure obviously). You might need to gravity feed it if its not flowing through...
But you will generally only get pressure once all the air is removed from the lines and the pump is pushing water only... Once you have water flow and lines are primed, switch on pump and see if that solves it.
SOURCE: Briggs and Stratton pressure washer will not spray
The nozzle on the end of the spray wand has a very small hole in it that can be easily clogged by any sort of debris that comes through the water supply.If the nozzle can be removed, just take a pin & clear the hole from the outside & rinse it off. If the nozzle can't be removed, then take the wand apart at the connector in the middle and do the same thing.
SOURCE: 2200 psi husky briggs and stratton pressure washer
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
SOURCE: craftsman pressure washer constantly fluctuates and then stops
sounds like fuel problem. Either water\trash at bottom of tank, or most likely, carb needs to be disassembled and bowl and jets sprayed out w\carb cleaner.my money is on the latter.
SOURCE: 18hp twin cylinder Briggs & Stratton backfire
Check to see if the carb is clean, if so the anti diesel value could not be working. Apply 12 volts to value and see if it move's. If that works then you may what to check the fuel pump and see if it pumps. After you tried all that then you may have change the main jet size because these engines come with a small jet for the EPA.
