When i connect to itunes the message "There is a problem with your iphone The iPhone you have connected may be damaged and cannot be activated for service.". Its was water damaged and after replacing all the faulty parts this happened. I tried recovery and didnt work. Warranty is finish so having it replaced is out of the options. please help
SOURCE: iTunes doesn't recognize iPhone SIM card
u pls jailbroke the iphone with redsn0w , then it will be
SOURCE: Iphone "There is not enough memory available"
There needs to be sufficient disk memory on the PC to hold the contents of the iPhone (8GB or 4GB) plus some extra. This is because the iTunes backs-up the iPhone before the restore. Check and clear some space on your PC hard drive and try again.
SOURCE: Cannot connect IPhone to 2wire :( HELP!
I had this exact same frustrating problem. The problem was a simple password issue. Although I had changed the password on the modem to my own personal one, that password only affected the administrator settings. When I used this particular password on my iphone it would put the checkmark next to the 2wire, but I would not get the wifi symbol at the top of the screen. I fixed the problem by using the 10-digit password supplied on the actual router instead. I told my iphone to 'forget' the network, then reselected it and when it requested my password I typed in the 10 digit number and 'presto,' i had wifi symbology! I hope this helps.
SOURCE: I have Iphone clone and I get ''no service'' when my AT+T sim card
I also had purchased an Iphone clone not to long ago. My service provider was AT&T. 90% of the time when my SIM card was inserted the phone would read "emergency mode". I would have no service, I wouldn't be able to receive or send any calls or text messages. I talked to AT&T representatives who would solve the problem for short periods of time but never gave me a permanent fix. I immediately sent the phone back to the seller. I have been doing a lot of research on these Iphone clones and I have seen quite a few times that people have problems in this area, not being able to have service. Also, what you have purchased and think is a genuine Iphone very well may not be. Many models of these Iphone clones now have the Apple symbol on the back and even have the Apple logo displayed on the screen when they start up. This being the case, you may very well have purchased a fake Iphone which would lead to problems with your service provider. I'm not sure how to fix the problem, and for this I apologize because I know how frustrating it is not to have service. But, I can tell you that your best bet may be to return the phone and try something else. All I've heard is that the genuine Iphone is the best way to go. Because these clones are made by independent manufacturers and not sold through AT&T, even though they may seem nice, many people have constant problems with service. Good luck, and if you find an alternative solution please let me know!
SOURCE: i tried to restore my iphone now its not detecting my sim
Go here and download the file that is for your phone. Connect in itunes and put the mouse over restore. Hold shift and click restore. Use the file you downloaded and let it work. You will have to use a at&t sim to activate it.
