SOURCE: my bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
SOURCE: I have Bosch Nexxt Premium WFMC6400UC Front Load
Hello and welcome to fixya.
I`d suggest removing the back panel and inspecting if the belt has perhaps come off.
**Unplug the unit from the wall first**
If so, put the belt around the motor pulley and start it around the drum/drive pulley. As you hold it in place spin the large pulley and it should go back on, careful not to pinch your fingers...ouch :(
Let me know what you find out or if you require further assistance.
If this indeed solves the problem please take a second to rate my solution accordingly.
Thank you for choosing`"fixya" and good luck.
macmarkus :)
SOURCE: Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
