SOURCE: Ink Monitoring System
I have this Canon MP600 using unchipped cartridges. Once you have changed the chip over onto the catridge and inseted it should stop flashing which indicates the cartridge is located. The printer will not tell you the level of ink until you run out. When changing the chip over from original cartridge onto unchipped ensure it is not damaged and fitting properly other wise the error sign will show.The printer should print without any problems, i know you can not disable the ink monitoring system. Hope this is some help Mr T
SOURCE: I disabled ink monitoring on my Canon IP4500, how
It will set itself back as you install new Canon inks, but will be turned off for the remaining inks until they are used up.
SOURCE: Reset Canon printer chip
you can override ink check status and manually reset it in drivers options
SOURCE: disabling Ink level Detection Canon iPF700
you can disable it only if an error occures at the first in filling, with the latest firmware installed (ver 1.37) if the machine will starts normally then you can't disable it.
SOURCE: how do i reset canon mp540 printer?/disable ink
These are instructions for the Pixma mp560 printer, I couldn't find the mp540 printer on the canonusa.com website.
I do not know how to disable ink monitoring levels.
Default Settings
Instructions to change the machine back to its default settings.
Note: Changes the settings back to the default (factory settings), except for the language for LCD messages and the position of the print head.
