I have recently purchased a sansa clip mps player uploaded a playlist on it from media player, went for a run. everything was fine until all of sudden the music started going all muffled. did reset music went back to normal but after naother 5 minutes or so same happened. thought it was perhaps battery wasnt charged but was fully charged up. very strange. any suggestions?
SOURCE: BAD TRACK ONCE AGAIN JUST WONT PLAY ANYMORE
You have a corrupt file - bad file...
Corrupt files for sansa -
Plug your player in, in MSC mode.
Right-click on it.
Click "properties"
Click "tools"
Click "Error Checking"
Check both the boxes on the error checking window that pops up, and click start.
After it finishes, check your player to make sure your player is normal.
If that don't work then format = http://www.sandisk.com/Retail/Default.as...
SOURCE: Sansa e260 - Stuck on "Refresh Database" after uploading music
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
SOURCE: Sansa Clip won't charge
Here's the thing, technically it doesn't need to be turned on because it's supposed to turn on by itself.
I've had a problem sort of like that. It might be the plug, but it also might be the computer. I'd either suggest try plugging it into another computer or getting a new plug.
SOURCE: sansa clip won't charge fully
If you have a phone charger with the same connector, plug in you Clip and leave it overnight. This will fully charge the battery. There is not enough power from the USB port.
