the left hand side light is flashing red and the one on the right is green, is this right?the left hand side light is flashing red and the one on the right is green, is this right?
You can't post conmments that contain an email address.
The throttle goes bad on those razors. You need to wire in a pushbutton toggle switch that can accept 24v... it is cheaper than buying the throttle but, it will be full on but, it is not like the thing is that fast.
The batteries should be 2 x 12v giving an output of 24v anything less than this the Razor Dirt Quad will not run. always make sure you buy genuine Razor replacement batteries.
Depends, some tabs are directly soldered to the batteries themselves so you will need a soldering iron to remove the tabs. After that, it wouldn't be too hard to remove and replace.
Keep in mind that these take 2x12volt batteries and these lead-acid type batteries may take a long time to charge depending on the current your charger is supplying.
If you plan to charge the two batteries with the stock charger, then you would have to wire the 2 batteries in series for 24volts (stock charger 24v) and for convenience you may also want to head out to your local electronics store to see if they have the female socket that the charger goes into, and possible some wire, connectors/tabs that attach to the batteries and possible some small alligator clips if required.
Yes a charge fresh, fully charged battery will allow for the scooter to perform at it's peak top speed. Also fresh, fully charged battery will read more than 24v on a voltage meter and this is ok.
Charge the batteries. If still no power than replace the batteries because they are dead. The batteries in the scooter need to be kept charged. If the scooter has not been charge in two weeks to a month and over. They are probably dead and need replacing. Find replacements at razor.com
