SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
SOURCE: Bosch Classixx 6 1200 express front load washer -
The 'start' button appears to contain a lock - possibly a child lock. Hold the button in for a few seconds to clear the lock
SOURCE: fabric softener dispenser no longer works on my Bosch
Remove soap drawer completely from washer, and thoroughly clean all parts of it, paticularly the conditioner compartment..
Get a piece of stiff wire, and make a right angled bend in the end of it, then poke the wire into all the holes in the top of the soap drawer compartment to clear any possible blockage.
This should solve the prob.
Please rate my solution.
Thankyou.
SOURCE: bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
SOURCE: Bosch classixx 6 1200 express has F17 on display
fault F17 error code appearing. What does this mean ? thanks
