I have an Insignia 9" dual screen portable DVD player (NS-9DPDVD) of which the main unit won't read the DVD. The unit hasn't been dropped, and quit working during the viewing of a DVD.
SOURCE: Insignia portable dvd NS Pdvd8 need battery
Hey redhouse2,
Because Insignia® is a brand primarily carried by Best Buy™ stores, there are two basic ways that you should be able to obtain a replacement battery: by contacting Insignia® technical support, or by ordering a replacement through Best Buy Partsearch.
You may always reach Insignia® by calling their toll-free hotline at (877)-467-4289. If you would prefer a self-service option, simply visit the www.Bestbuy.com website, and follow the link at the bottom of the page that says "Order Parts." Additionally, you may always contact a Partsearch agent by calling our toll-free hotline at 888-Best-Buy (888-237-8289), and requesting to speak with a parts specialist.
Please keep in mind that while some third-party companies may carry compatible batteries for this model, if your DVD player is still under the manufacturer's warranty (or a Best Buy Performance Service Plan) you may wish to seek the replacement part through Insignia® or Best Buy™ first to avoid any unnecessary charges.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
SOURCE: insignia NS pdvd10
Unlock
Insignia NS pdvd10
It`s really works
1) On the remote control type "SETUP" button
2) Select "PREFERENCES" in the menu with
3) Validate it with the button "OK"
4) Enter the code : "224455"
5) With the direction keys type:
a) Left key : < (Nothing happens)
b) Down key : v (a menu appears on the screen
with all region)
6) Select the Region : 0 (all) with the direction keys
7) Validate it with the button "OK"
8) Finish the process by typing the "SETUP" button.
SOURCE: portable dvd player insignia ns-pdvd10 screen problem
Check the screen switch on the right top side where the door closes there is a little circle and the release switch usually gets jammed (this is a common defect) you will need a small thin flat head screwdriver to pry out the switch.
SOURCE: insignia portable player NS-8PDVDA not working
Here's how I've solved same symptoms with our NS -PDVD8a:
1. Cleaned laser optics with isopropyl alcohol/swap --make sure you let the optics dry/IPA evaporate from the optics before running
2. Using compressed air can--cleaned laser track
3. Gently move laser along track several times - it seems laser is having most trouble at start of disc -- not sure it needs lubrication, but running it along track several times seems to have righted it
Had to do this a couple of times, but it's working now -- expect I will need to do this again -- no idea how long fix will work.
SOURCE: Insignia NS-MVDS7/9 - unlock code
This information was found on the following website http://www.videohelp.com/dvdhacks/insignia-ns-7dpdvd/8394 It is dated as working on 01-08-08. I hope this information help you with your problem. 1.- Power on with no DVD inside the player; 2.- Press open on the DVD player; 3.- Press Menu button on DVD (or SETUP on remote control), (you see General Setup Page on the screen); 4.- Press the right key 3 times to select the Preference Page; 5.- On the remote control press 9653; 6.- Use the up and down key to select the Region, Select 0 for all regions; 7.- Press Enter. (This works with NS-7PDVD and NS-8PDVD)
