A microSD that has a crack in it is, most of the time, unrecoverable. All of the "innards" to the microSD are closely packed together. So, any significant bend, or especially a crack in the card, pretty much means the card is gone.
That being said, give these guys a shout and it is possible you may be able to get your data back.
https://datarecovery.lc-tech.com/
Connect your SD Card to PC with Card Reader ,and then follow the steps:
Download Hodo photo software online
Open the photo recovery software and follow the list steps to recover:
http://www.goshareware.com/resource/micro-sd-card-data-recovery.html
Accidentally deleted an important file? Lost something important when your computer crashed? Want to recover data from Memory card? No problem! Tenorshare Data Recovery can recovers files deleted from your Windows computer, Recycle Bin, digital camera card, or MP3 player.
You can download it on this website:
http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
You can use Card Data Recovery. It is the professional SD card data recovery software. It can recover photos, video, audio and documents from SD card, miniSD card, micro SD card, etc. This program has two versions, one for Windows users, one for Mac users. You can visit its official website to have a look.
Card Data Recovery for Windows
Card Data Recovery for Mac
SOURCE: pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
SOURCE: problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
The problem is that a 4 GB micro sd card is HC (High Capacity). You will need to buy a card reader that can read HC micro sd cards (cost +/- € 8).
Very important: check if your mobile phone works with high capacity micro sd cards because a lot of phones don't work with HC micro SD cards.
Don't forget to rate, thks
SOURCE: Micro SD not reading
If you are unable to access/view the contents of the card, chances are, it needs to be reformatted for it to work again, which means, data will be loss. You may, however, try to search the web for a data recovery program which you can first try to use before reformatting the drive.
SOURCE: i cannot format my transcend micro sd 1gb card nor
it means that the memory card's sector is damaged by a virus infection...try to delete the files while in the mobile and then format it..if it agains appear the same then you've to buy a new card only`
SOURCE: My Micro SD Card No.- Kingston 2GB micro SD Card
My Kingston Micro sd-c02G is Locked i want unlock password
Hope this helps
