Any one answer me my tv all21pin scart not working
Did it ever work? Was it working and then stop working? Did you push the correct input on remote. The problem could be the board inside t.v. In U.S.A. we don't have that on our teleivisions and I don't have any diagrams for euopia sets. Sorry can't be more help. Are you French? Always try to give as much information as possable when posting. Good-luck, If not a setting with remote, or bad cable, try unpluging power for 5 minutes. If still not working, problem inside T.V. is my best guess. Good-Day.
The connection standard requires that the pins are utilised in the following manner:
Hope this is useful.
PIN USE LEVEL / IMPEDANCE 1 Audio Output (R) 0.5V / 1K-ohm 2 Audio Input (R) 0.5V / 10K-ohm 3 Audio Output (L) 0.5V / 1K-ohm 4 Audio Ground -------------------- 5 Blue Ground -------------------- 6 Audio Input (L) 0.5V / 10K-ohm 7 Blue 0.7Vp-p / 75ohm 8 Status (CVBS) L:0-2V H:10 - 12V / 10K-ohm 9 Green Ground -------------------- 10 Data D2B (Inverted) -------------------- 11 Green 0.7Vp-p / 75 ohm 12 Data D2B -------------------- 13 Red Ground -------------------- 14 D2B Ground -------------------- 15 Red 0.7Vp-p / 75 ohm 16 RGB Status/Fast Blanking L:0-0.4V H:1-3V / 75 ohm 17 CVBS Video Ground -------------------- 18 RGB Status Ground -------------------- 19 Composite Video Output 1V / 75 ohm 20 Composite Video Input 1V / 75 ohm 21 Case Shield ---------------------
A 21 pin SCART cable with all pins connected is wired as per the following diagram:
Hi i have philips 32 inch wide screen tv tv working ok i have problem 21 pin scart both of them no working with aney equipment please tell me what is fault in the tv model 32dw6557/05 made from france
hi i have philips tv wide screen that all 21 pin socket not working only audio sound ok but not picture on the screen and not working on wide screen or super wide or 16.9 please tel the problem
Could you try typing that one more time please? Proof-read what you write.
