The plastic spindle base gear
SOURCE: Magic Bullet Blender Repair
i had the same problem,broken plastic drive gear.
solution ; sacrifice one of the blender choppers bases you use the least (usually the flat cutter)
hold the cutter blade with pliers or in a vice if you can and unscrew the rubber gear off the shaft in a clockwise direction -- CLOCKWISE--DIRECTION-- easy huh.
Now insert screwdriver to suit,(coss,phillips or flat blade type) into centre hole in underside base of power head drive unit. Hold unit firmly and now unscrew broken gear or brass centre piece left behind CLOCKWISE again off spindle.
Finally screw rubber gear back onto motor spindle in ANTI clockwise direction. DO NOT over tighten. Rotation of motor and drag caused by blending action tightens assembly with use.
Done. for pics follow this link
http://www.ehow.com/how_5137984_repair-magic-bullet-blender.html
SOURCE: My Magic Bullet has broken. I need to know how to get it fix.
This happened to me, and I was told by the company that I had to purchase a brand new base, that the plastic turning device can not be repaired. If it is under warranty, you may not have to pay anything but shipping, and maybe not that either. If you do not have the number to the company, go on-line and and search for it. Call the company and report what the problem is.
SOURCE: my plastic
So, rather than pay for an entire new motor and wait for two weeks forthem to get it to me, I just made a new gear/broken thing. I crazyglued the old piece back together again and used it to make a plastermold...like the way people do with their kid's hands. Then I filledthe mold with JB Weld and let it dry. After that, I drilled a hole inthe new JB weld gear so that it would fit over the metal part in thebullet(that actually spins).
Glued it on (with more jb weld) and the thing has been making my smoothies and grinding my coffee with no more issues.
Sounds complicated, but it wasn't too bad. Funny thing is, the newpiece is probably heaps stronger than the cheap plastic thing thatbroke in the first place.
Do it yourself,
I'm tired of made-to-break products and could make anyone else one of these things for around 10 bucks!
SOURCE: my magic bullet stops rotating
The Magic Bullet power base is designed with HIGH TORQUE MOTORS and it is NOT TO BE USED FOR MORE THAN A MINUTE PER USE.Otherwise its gonna last a long time. You need to buy a new one or a refurbished one. Search google with keywords "amazon magic bullet power base".
SOURCE: my magic bullet has lost the plastic bits that
