The dispense tray is filled with Washing powder and the middle section is loaded with liquid softener. The machine takes the powder but at the end of the cycle the softener is still in the tray and has'nt been utilised?
I have checked and cleaned the dispense tray which shows no damage.
We did not have this problem when we first had the m/c? Bosch WFL 2872 Front load washing m/c
Don't use powders!
they gum up the works
so you need to keep cleaning out the system and maybe replacing the valving part.
use very hot water in the dispenser a few times. let soak too
Hi. Assuming the washer has completed the rinse sequence, there is a possibility the dispenser part of the valve could be faulty. I assume that you have put the conditioner in the right compartment of the dispenser.. If all else seems to be o/k, I recmmomend thay you once again thouroughly strip and clean the dispenser..
The other possibility is that the hole where the water comes in at the top of the dispenser is blocked.
You need a stiff piece of wire with a hook on the end and poke each hole that you can see in the top of the dispenser compartment
This should solve the problem
Please leave feeed back.
Thanks
My wife tells me she lifted the click down flap of the softener section so that the flap was in a raised position eg: not fully engaged, and this worked. Don't know why but thanks anyway.
I have the ame problem, both the softner & bleach will not dispense. My machine just passed the warrenty and a service call & parts are costly. Can any one help?
