I need to connet the ribbon cable to the mother board
SOURCE: Downloading skype onto my acer aspire one netbook
For aspire one you need to download the Fedora 7 package from the Skype Website.
Afterwards, just do what your aspire asks you to do. When everything is installed, just press alt+F2, type in "skype", en press "Run". Skype will start up. That's it
SOURCE: No LCD connectivity
Hello, I am using a Viewsonic lcd projector with my new Acer Aspire One. I did not have connectivity off the bat. Here's what I did: 1. Downloaded driver (unsigned, not the signed version worked - ie not os-specific) for the lcd projector to the Acer. Restart Acer. 2. With lcd projector connected to Acer, toggle function key & F5. But then, continue holding down the function key. A screen pops up with icons for laptop, laptop/monitor, dual monitor, and lcd projector. You continue to hold down the function key and then press the F5 key to move to the desired device. I had to repeat the same process to restore my Acer screen to the original proportion when not using lcd projector. I'm not sure if both steps 1 and 2 are necessary, but I did it simultaneously, so I'm not sure of the origin of success.
SOURCE: Screen flickers on Acer Aspire A150 Netbook
It really sounds like you have a short in the ac adapter. Laptops dim the backlight on the screen when on battery power and go full brightness when on AC. I think your adapter is going on and off. When it is on the screen is on full and when it goes off the screen dims down a bit. You could have a bad adapter, most likely, or a bad charging jack in your laptop. Check the adapter first, just use a multimeter set to voltage. Read lead goes to the center pin and black lead goes to the outside metal contact, you should get a reading of 18 to about 26 volts. Move the wire around near the plug that you are holding and keep checking the readout. I think you will find the voltage dropping as you move the wire.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: Flat cable
http://www.specialty-cables.com/flat-flexible-cables.html
E-mail them. They have Flat Flex Ribbon Cables, from 0,5mm to 2,5mm pitch, and 3 to 40 conductors - so they have the cable you are looking for. Please rate me :)
SOURCE: my acer aspire one netbook wont connect to the
Check the power settings. It may be turning off the NIC/Wireless Card when you are running on battery to preserve battery life. Turn it on.
