1. Press the flash/program button until “1ENG 2FRA 3ESP “ shows in the display.“1ENG “ is the default setting.2. Use the cid/vol (+ or -)button or the handset number pad to enter your selection.3. Press flash/program to store selection.
You can only install in a language you have a license for, you should contact Adobe about this issue. If it wasn't in the installation choices, you probably don't own it. Else if you do, reinstalling is the only option to change the language of all products in the master collection.
The problem is not the disc itself but your DVD player. If other discs still play in English, and it is just this one disc that plays in Spanish, then your player is using some sort of stored setting to recognize your preference for spanish on that particular disc.
Forgive me if you've already done this, but try turning unplugging the DVD player for a period of ten seconds or so, and then plug it back in. If there is a reset button, press it. See if the disc still plays in Spanish after that.
If so, you may need to navigate the DVD menu of the offending CD to turn off the language setting your daughter selected. If you don't speak Spanish, try navigating to the language settings on one of the other discs with the English menus. Memorize how you got there, and take the same path through the Spanish language menu. Return the language setting to English, and exit.
Hope this helps.
Make sure your TV hasn't been set for SAP (you'll find it in the audio settings menu). Second audio programming is often used to carry alternate languages, and if it's turned on you won't know it until you watch a program where it's being used. There may be a single button labeled SAP on the remote. If so, it's easy to change the TV setting without realizing it.
Oh boy that's a real problem. I guess the menu is there but you don't understand it because it's in Spanish.
I don't know this particular phone but thinking logically, there are four things I would consider.
1) Find someone who can speak Spanish, there are lot of people who can.
2) Find someone who has the same phone that is in English and copy the key presses.
3) Use Google language tools to help you interpret the Spanish menu
4) Take you phone to a dealer
You can go to the menu like you always do, and since spanish is similar to english you can use parts of the forgien word to switch back to english. (or if you still remember the options in the menu, you could just scroll down as normal).
To return the base announce language to english press and hold the skip button for two seconds.
To change the display language in the handset press the flash button, then use the CID button to sellect english, then cycle thru the rest of the menu by pushing the flash button until done.
Hope this helps!
