Hello everyone, I am hoping someone can help me with this problem. My father's laptop all of a sudden comes up with this message Wireless is Turned off! the wireless devices on your computer are turned off. to turn on the wireless devices, press the wireless button. Simple enough, the wireless button is F12, we press it and nothing works. Still the same problem. I run a trouble shoot and once again windows network diagnostics tells me Turn on wireless capability. Please help.
SOURCE: HP Pavilion dv5 how to turn on wireless capability
where you see the light for you're wireless connectivity (blue when enabled) should be red now, just tap it once to turn it back on.
SOURCE: wireless radio switch
Page 13 will show you the radio switch. It is the 4th button.
Wireless switch Turns the wireless feature on or off, but
does not create a wireless connection.
✎ A wireless network must be set up in
order to establish a wireless
connection.
http://h10032.www1.hp.com/ctg/Manual/c01035586.pdf
SOURCE: Medion Akoya Multimedia notebook - wireless capability
press the fn key then i think its the f5 key but which ever f# it is it has kinda like wavy lines on it read the instruction manual too it does tellyou
SOURCE: i cannot turn on my wireless capability
To the satellite E105 S1402 with WiFi problems. The solution is:
1. Make sure that your router is operational.
2. Make sure that the WiFi switch is on.
3. If your Wifi used to work out of the box, then you need to buy a Flash Drive (if you don't already own one), then you need to do a Backup of all your users documents on the Laptop.
4. Use the CD's that came in the box to re-install Vista 64.
Don't waste time with Toshiba support, you will end up in Phillipines and quite honestly, I am shocked that Toshiba does not have a better support process.
I had the same problem and I had to re-install the OS. It is not that painfull to do and should take about 1/2 hour.
Cons: You have to re-install additional software that you installed after purchasing your laptop.
SOURCE: turn on radio button of my wifi NEC VersaProVA11J Laptop.Please H
two things you may wanna check
if the wireless is enabled in your network settings
and 2nd may be there is a Fn key +some other key combination for the wireless
