When i inserted the new card into my computer i was asked to format it. i did. now it has only 0.97mb of memory on it. did i lose all 64gb of memory by formatting it?
No, you didn't loose memory. You just have to reformat it. When you do, check if you can change the total capacity with drop down menu, also try settings it to FAT32.
If not, you could use another computer or even a portable device like cellphone or camera to try and format it.
Don't worry, you cannot 'loose' the 64gb.
Testimonial: "when I inserted the card into my Galaxy 3 phone it was possible to format it back to its 64gb volume. I believe my problem with the PC Windows 7 had to do with using a card reader that does not work with SDXC cards. I will shop for a better reader and recheck after that. thank you"
Reformat it again and that shall solve your problem
SOURCE: sandisk micro sd card forget password in nokia
Try putting the memory card in your PC and formatting it from My Computer.
If you have a camera that takes this kind of card, you can try to format the memory card from there as well.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: how can i format my locked micro sd
my memory card wants password but i did not create password in my memory card.so my memory card is locked.how can i solve this problem?
SOURCE: I purchased a 4GB Sandisk
your samsung Gravity 2 wont read the HC format, there is not much you can do sorry. the SD HC is a newer format for devices in the last year or so. Older devices will not accept the HC format cards. I did the same thing! And im in the business, easy mistake. Keep it around though you'll use it soon, just not in your Samsung. Gurvy
Testimonial: "thank you, I realize this was the case... in my opinion, the SD/HC card manufacturers should put a warning on the packaging. I did get my money back. "
SOURCE: how to format my corrupted
If you a using a card reader that plugs into your PC and it STILL doesn't read from the card, this means that the card itself is defective and needs to replaced. You CAN try using another card reader to see if that helps.
Hope this helps. :)
SOURCE: i cannot access my 2GB
i
cannot access my 2GB micro sd card in computer or phone, when i opened
it from computer i get message card need to be formated but when i
start to format card windows says unable to format this device. please
help me.
from kapil sharma
I hope this helps.
when i inserted the card it was brand new and empty.
