I have a box full of AC adapters but am uncertain which one to use.. Manual is no help.
See the plate label indicating the serial number, model, and indicating the electrical specification. And proceed according.
Otherwise you must call to the company for customer service and get help online via chat.
God bless you
SOURCE: My pro form elliptical is no longer getting power
1) Measure the outlet plug with another device such a lamp desk 115Vca.
2)If there are voltage with the lamp , the problem is with the fuse+c.breaker in your treadmill.
3)If there are NOT voltage with the lamp, the problem is c.breaker from your house Reset.
4) If after you reset there are NOT voltage again, the problem is the wires had been isolated with the paint, You must take out the paint, for to conduct the electricity to the outlet, and try again with the lamp desk
see the diagram.
God bless you
SOURCE: what type of AC adapter does the T790 ellictical
Dear Sir:
Please read carefully:
Your treadmill, like any other type of sophisticated
electronic equipment, can be seriously damaged by
sudden voltage changes in your homeõs power.
Voltage surges, spikes, and noise interference can
result from weather conditions or from other appliances
being turned on or off. To decrease the possibility of
your treadmill being damaged, always use a surge
suppressor with your treadmill (see drawing 1 at
the right).
To purchase a surge suppressor, see your local
PROFORM dealer or call toll-free 1-800-366-7278
and order part number 14657. Use only a single-outlet
surge suppressor that is UL 1449 listed as a transient
voltage surge suppressor (TVSS). The surge
suppressor must have a UL suppressed voltage rating
of 400 volts or less and a minimum surge dissipation of
450 joules. The surge suppressor must be electrically
rated for 120 volts AC and 15 amps.
This product must be grounded. If it should malfunction
or break down, grounding provides a path of least
resistance for electric current to reduce the risk of electric
shock. This product is equipped with a cord having
an equipment-grounding conductor and a grounding
plug. Plug the power cord into a surge suppressor,
and plug the surge suppressor into an appropriate
outlet that is properly installed and grounded in
accordance with all local codes and ordinances.
If you need Extra help please reach me inmediately.
sincerely. blessing.
E.CUADRA
MANAGUA, NICARAGUA .C.A
I have no "plate" or "label" from which to determine the electrical specification, hence my seeking help here.
The company website (newbalancefitness.com) is no longer functional.
