Vizio VA220E 22 Class LCD HDTV - 720p, 1366 x 768, 60Hz, 5ms, 5000:1, Logo
megan Neidhamer Posted on Jun 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No signal turn on screen says no signal
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Jun 19, 2012
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3737105
Points
36074
Check your video settings to make sure tv is on tv or catv. catv is for cable. If you have neither, then your tuner is bad.
2answers
Turn signal goes out 2015 Dodge Ram 1500
Did you hook up a professional grade scan tool an check for DTC'S - diagnostic trouble codes? You keep seeing the left rear turn signal is out message on driver panel screen. That's the DIC driver information center. Could be a problem with the TIPM - totally integrated power module.
Chrysler TIPM Problems: Vehicle Symptoms for TIPM Failure (tipmrebuilders.com)
1helpful
What is a RGB signal
RGB means Red,Green,Blue it is an old system for supplying video signal to a screen..
I have astron tv 14 inches. when i connect outdoor antenna the. tv screen turn black. no signal. no reception but when i disconnect the outdoor antenna it turn to blue screen.
blue screen means 'no signal' or 'signal level is too low' whereas black screen means that there's a signal. Check your antennae, do a factory reset to your unit and then try initial setup.
Failed signal
Yes, check the cable as your tv's tuner does not receiving signal. The BLUE SCREEN on most of this brand means you have no signal from an outdoor signal or so. Thanks for using Fixya.
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
2helpful
2answers
Emachine T6410 turns on but the screen says ''No Signal''
This problem is very common when you have a bad ram/ memory module or it is not making sufficient contact. Remove them and clean with a piece of dry cloth and reseated properly. Try it again. If it is still not coming on, the ram may be bad. Get them tested and replaced.
Thanks,
Lolita
TEAC LCD191SD WIDE SCREEN LCD TV WHY NO SIGNAL
U have a signal word bound around or said no signal in ur LCD Screen?Than it ur colax cable not getting signal comming in.Try reset ur cable or satalite box by turning it off/on.IF the LCD screen totally black,try unplug,replug might get picture back.Not than must replaced the main video backlight board it dead must be replaced.
No input signal on screen
that usually happens when your pc isn't turned on
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
