Kenmore HE2 Plus Front Load Washer Logo
Posted on Jun 18, 2012
F- 24 error in kenmore - Kenmore HE2 Plus Front Load Washer
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 18, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
338
Points
6
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
F-24 flashing on Kenmore He washing machine.
F24 error on an ASKO is something to do with the water temperature sensor. Apparently the Asko is the same a s a Kenmore?? Look up ASKO F24 error on "Google" there is a bit more info.
Kenmore oasis elite dryer trouble shoot f-24 error kenmore
According to the manual, follow these steps:
  • For an "F" error on your Washing Machine.
  • Select PAUSE/CANCEL twice to cancel the cycle.
  • Select DRAIN & SPIN if there is excessive water in the washer.
  • Re-select cycle and press START.
  • If the problem remains, call for service.
Here's the full manual: Kenmore 110.45986400 Owner's Manual
1helpful
F 24 error code
Hello there and welcome to fixya
the f-24 error code is a temperature sensor failure code
The NTC, or temperature sensor, is located under the bottom front of the wash tub. It is a small square black plug between the heating element terminals. In many cases the connector plug comes loose and simply needs to be reconnected.
If the NTC is defective, a replacement can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites have helpful exploded view diagrams that you csan use for reference to locate and correctly identify the parts you need. The NTC is listed as item 26 under the "Tub and Motor Parts" heading. If the model number is correct, the part number you need is 8181705. The average cost is about $10. You can view an image of the part here:
http://www.appliancepartspros.com/part_details.aspx?part_id=3128829&pn_=8181705
I have a model #110.47561601, Kenmore HE2t Front load washer Type 832. I am getting a code of F-24, when I try to start the cylce. What is the problem that prompts a F-24?
Hello
F-24 is a water temp snsor error.Try running the machine in spin and drain.Once empty unplug machine for 3 min.Then try load of wash again.This time use cold water until error clears.
Kenmore Refg Displays DH on the screen after 24 hrs, is that a defrost problem
DH = Defrost Heater.
Kudos to kenmore for making an error message that makes sense.
Since the defroster timer turns on the defroster heater once every 24 hours, this makes sense.
I have f11 error code
This is not a known error code.
Please re-check and re-post.
Thanks!!
1helpful
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Alexander
vince
