Indesit W 123 Front Load Washer Logo
Graham Posted on Feb 01, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No power to my Indesit Washing Machine.
My Indesit washing machine was in the middle of a wash when there was a power cut. The power to the house was resolved but no nothing happens to the washing machine, it is dead. I have checked the fuse and plug, all OK and there is poser going to the machine (it has been checked with a tester).
Russ Hill
Level 3:
  • Indesit Master 4,057 Answers
  • Posted on Feb 01, 2018
 Russ Hill
Indesit Master
Level 3:
Answers
4057
Questions
10
Helped
1175482
Points
12696
PCB has suffered a catastrophic failure due to the power cut, it will need to be replaced. if you have a power cut in the future always turn off your appliances, as the voltage can exceed the appliance recommended voltage. only leave a light on as lights can take the over voltage unless they are led type, you can but power drop sockets that when power is off it turns of the socket off so no power goes thought to the appliance.
5 Related Answers
Anonymous
  • Posted on Feb 27, 2008
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Anonymous
  • 247 Answers
  • Posted on May 07, 2007
SOURCE: washing machine blown fuses
Can't promise it isn't the motor, but there are other suspects (maybe more likely, and probably cheaper to fix). Few questions: 1. Do you have a RCCB (also called an RCD, Residual Current Device, Current Operated Earth Leakage Trip etc.) protecting your ring mains? (How to look for one: If your wiring is less than fifteen or so years old, it might be built into the main switch on your fuse box, if a little bit older, you want to look for a separate box - usually grey, about the shape and size of an After-Eights box, with a big switch and a test button on). 2. What stage of the cycle does this happen at? 3. If it always happens during the "wash" phase, can you make it happen at all if you run a series of cold wash cycles? (don't need to have laundry or detergent in the machine to test this). A.
Anonymous
  • 641 Answers
  • Posted on Aug 16, 2007
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Anonymous
  • 209 Answers
  • Posted on Sep 09, 2007
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
ashburton
  • 417 Answers
  • Posted on Jan 23, 2010
SOURCE: washing machine is not draining and lights keep
It is likely that the pump/filter has blocked thus preventing the water pumping out.
You would need to check and if so unblock it. The location of the pump/filter varies with the brand but sometimes it is behind a flap at the lower front of the machine whilst on others you have to get the back off to locate it.
Testimonial: "that worked a treat thanks"
Please help me, I need indesit 4²1 washing machine door gasket white color, thank you for your help
Something is strange with your model number. All spares are available from the maker.
Genuine Gaskets & Seals - Indesit Washing Machine Parts
parts.indesit.co.uk > category > gaskets-seals
For Genuine Indesit Gaskets & Seals you've come to the right place. Restore your appliance with our huge selection of parts. Next day delivery available.
How to Replace an Indesit Washing Machine Door Seal ...
www.espares.co.uk > ... > Washing Machines
How to Replace an Indesit Washing Machine Door Seal · Step 1 - Safety Advice · Step 2 - Decide How You Want To Replace The Door Gasket · Step 3 - Remove ...
Indesit Washing Door Seals Parts for sale ' eBay
www.ebay.co.uk > ... > Indesit Washing Door Seals Parts
Results 1 - 48 of 443 - Indesit Washing Door Seals Parts. Side Refine Panel. Shop by category. Washing Machines & Dryers; Washing Machine & Dryer Parts ...
1helpful
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Trip switch cuts out when i use washing machine
Main board power circuit fault.disconnect main PCB and reconnect power cable .you can identify the fault. Replace main pcb.
1helpful
Indesit Washing Machines
27 KVA is a huge generator and should work just as well as the grid. The only thing I can think of is the startup current, which can easily be 5 times the running current is playing havoc.
You might try tightening up all your lugs and screws in your panel. A loose neutral can create some truly weird problems.
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
All lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
2answers
Indesit wie157 washing machine. led displays error code "door", ive bought a new interlock and replaced it but it still wont work, what is wrong? thanks paula
Make sure the door is positively latched in.,some times a weak or broken door spring or striker is the cause of the problem, if you are satisfied these are o/k, then it is probably a control board problem, and you will probably have to call an engineer.
Plz rate my solution.
Thanks.
Top Indesit Washing Machines Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Sean Wright
Sean Wright
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
