My tv wont turn on or off, every time i tried a screen keeps popping up saying "tv keys aren't programmed". Also the tap thing is on the directv logo, and i tried it with av1, av2 and tv, and it still isn't working.
SOURCE: need code for Directv remote for 26LG Flat Screen TV
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
SOURCE: I have a Directv RC24 remote control. I am trying
Programming DIRECTV Remote
1. Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
2. Locate the 5-digit code for your DIRECTV Receiver (see
page 10).
3. Power on the DIRECTV Receiver.
4. Move the slide switch to DIRECTV icon.
5. Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
6. Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
Magnavox codes:
11454, 10054, 10030, 10706, 10179, 11254
7. Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
code.
8. For future reference write down the working code for
your DIRECTV Receiver in the blocks below:
Once you have programmed the DIRECTV remote control for
your TV, you may want to activate the TV Input button.
1. Move the slide switch to the position under TV icon.
light under the TV icon flashes twice and then release
both keys.
3. Using the number keys enter in 9-6-0 (The green light
under the TV icon will flash twice)
You now have the ability to control the Input select feature for
your TV.
SOURCE: I have a Oritron DVD player,Need Dirctv remote Code for DVD Playe
Try calling Oritron. If you are lucky, your DVD player is simply a rebadged model from a major manufacturer and there may be other codes they can suggest.
SOURCE: directv rc23 remote - new Viore 42" TV, Model v42rmfj
hold the mute and select button down till the light blinks at you ( note the remote must be in the tv mode ... switch on top all the way to right) once the light blinks enter 991 then pause a sec and enter 1 again then use the chanel up till unit turns on then hit select button repet till all functions work
SOURCE: My DirecTV remote completely quit working. I
Is the DVR the problem or the DirectTV remote?
If it's the DVR, DirectTV will send you a replacement and you will have to return the faulty unit. If it's the remote, you can buy a replacement online at directtv.com.
Direct Code Entry
To program your universal remote to control your components
using the Direct Code Entry Method, follow the steps below.
1. Manually turn on the component you want the remote to
control.
2. Locate the enclosed Code Lists. Find the list for the
component you wish to program. Find your component's
brand. You will see a listing of four-digit codes for each
brand. If your brand isn't listed, use one of the Code Search
methods to program the remote control. (Refer to pages 3
and 4 for Manual and Auto Code Search methods.)
3. Press and hold the component key (TV,
VCR•DVD, SAT•CBL) you wish to
program. The illuminated ON•OFF key
turns on and remains on. If you release
the component key at any time during the Direct Code
Entry procedure, the illuminated ON•OFF key blinks four
times, and the process is exited.
4. While holding down the component key, consult the
Code Lists for the four-digit code that corresponds to your
component's brand and use the number keys (0-9) on the
keypad to enter it. While you are pressing the numbers, the
illuminated ON•OFF key turns off.
5. After the fourth number is entered, the illuminated ON•OFF
key turns on. At this time, release the component key. If the
illuminated ON•OFF key turns off, you have entered a valid
code and have followed the correct procedure for Direct
Code Entry.
If you enter a code number that is not in the Code Lists or
you do not follow all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks four times when the
component key is released. This is an indication that a
programming error has occurred. In that case, repeat the
Direct Code Entry process from step 3.
Tip: Throughout the programming of each key, be sure to keep the
remote pointed at the IR sensor of the component you are currently
programming the remote to control.
6. To confirm that the component key is programmed with
the correct code for maximum functionality, test the
component. Attempt to control a variety of the component's
functions with the remote. If some of the features of your
components do not work, try programming the remote with
a different code in the list until you find the code that allows
the remote to control the majority of your component's
functions. Different codes can provide different levels of
functionality.
OK.
you want the remote to control.
Find the list for the component you
component's brand. You will see a
one of the Code Search methods to
to pages 7 and 9 for Manual and
(TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated
ON•OFF key turns on and
remains on. If you release the
during the Direct Code Entry
ON•OFF key blinks four times,
component key, consult the Code
corresponds to your component's
(0-9) on the keypad to enter it.
numbers, the illuminated
off, you have entered a valid code
procedure for Direct Code Entry.
in the Code Lists or you do not follow
four times when the component key
a programming error has occurred.
In that case, repeat the Direct Code
TIP
of each key, be sure to keep the remote
is programmed with the correct
test the component. Attempt to
component's functions with the
your components do not work, try
programming the remote with a
find the code that allows the
your component's functions.
different levels of functionality
OK
10017, 10154, 10451, 10236, 10463,
10180, 10178, 10171, 11394, 11963
Load the remote with new batteries and proceed.
[1] Manually turn on the component you want the remote to
control
[2] Press and hold the component key (TV,
[3] While holding down the component key, consult the
[4] After the fourth number is entered, the illuminated ON•OFF
Code Entry.
[5] To confirm that the component key is programmed with
functionality.
OK.
Direct Code Entry lets you enter a code from the accompanying
code list for your brand of device. It's not as easy as the other
methods, but it's potentially the fastest method
TIP: Each device key is associated with a type of device-
the TV is preset to search for TVs, SAT•CBL•DTC for satellite
receivers, cable boxes or digital TV converters, DVD•VCR
for DVD players, and DVR•AUX for DVRs. To program a
device key for a different type of device, see the Changing a
Key's Device Type section.
1. Manually turn on the device you
want to contro
2. Find the Code List that came with
the remote. Locate the section for
the type of device you're trying to
program, and find your brand in
that section. Circle the codes for
your brand and keep them handy.
3. Press and hold the device key you want to program (the
POWER key illuminates).
While you're holding down the device key, use your other
hand enter the first five-digit code for your brand in the
code list (the POWER key turns off after the first digit).
4. When you've finished entering
the five-digit code, keep holding
down the device key and look at
the POWER key.
Is the POWER key
illuminated?
YES: You're done! You've programmed this device key.
NO, it blinked four times and turned off: You have
either entered a code number that is not in the code lists
or missed a step in the code entry procedure. Try step 3
again
NOTES
Test the remote with the device to make sure the device
key is programmed with the correct code for maximum
functionality. If some features don't work, try a different code
in the list.
Remember to enter the code for future reference in the box
provided in the Code Retrieval section of this manual.
If your brand isn't listed in the code list, use one of the Code
Search methods to program the remote control. (Refer to the
Auto and Manual Code Search methods.)
If you release the device key any time during the Direct Code
Entry procedure, the POWER key blinks four times, and the
process is exited. The last programmed code under the
device key is retained
Codes to check with Sylvania are:
20035, 20081, 20000, 20043, 20593, 21593
11864, 10054, 10171, 11271, 11314
51563
OK.
1* Manually turn on the component you want the remote to
control.
2* Locate the enclosed Code Lists. Find the list for the
3* Press and hold the component key (TV,
4* While holding down the component key, consult the
5* After the fourth number is entered, the illuminated ON•OFF
Code Entry
6* To confirm that the component key is programmed with
functionality
control.
Code Entry.
functionality
Ok.
Direct Code Entry
methods, but it's potentially the fastest method.
[1] Manually turn on the device you
want to control
[2] Press and hold the device key you want to program (the
[3] When you've finished entering
the POWER key.
Is the POWER key
illuminated?
again
