Question about U-Line ?chelon 2175RB-00
How to bypass refrg thermostat - U-Line ?chelon 2175RB-00
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
I believe this an electronic verstion if so not able to jump
Posted on Nov 22, 2013
6ya staff
SOURCE:
Where is 1992 mazda protege thermostat bypass hose?
I don't know.
The idea of a bypass hose is rather old-fashioned and mostly these were deleted decades ago due to the fact they slow the engine warm-up.
These days the bypass, if required is either an internal port or if the heater matrix is permanently supplied with coolant it performs the function of a bypass.
Most modern engines are fitted with a degassing system and that is perhaps what you are thinking of. Earlier types often circulated a small amount of coolant from under the thermostat to prevent gas accumulation interfering with the thermostat operation while some later types were connected above the thermostat and sometimes the radiator.
May 27, 2018 | Mazda Cars & Trucks
Having a promblem taking off crossover exhaust pipe on a 2005 Buick rendezvous I tooken off the two front exhaust Then took bottom two bolt . But still fasten to something is there other bolts...
Thermostat? engine cooling?
2 engines, here, LYA adn LY7.
nobody here posts engine, why do that?
so ill post only for 1.
the LA1
here are the steps.
NO FSM Sux huh? nor an alldata.com account, why not that? 15 bucks?
STAT out.
Remove the air cleaner and duct assembly. Refer to Air Cleaner Assembly Replacement in Engine Controls - 3.4L.
Drain the coolant until the coolant level is below the thermostat. Refer to Cooling System Draining and Filling (Refer To List 1) .
Remove the crossover exhaust pipe. Refer to Exhaust Crossover Pipe Replacement (Refer To List 2) in Engine Exhaust.
Remove the radiator hose from the thermostat housing.
Remove the thermostat housing bolts and clean any sealer from the bolt threads.
Remove the thermostat housing and gasket.
remove STAT
next is crossover page.
Disconnect the battery ground (negative) cable. Refer to Battery Negative Cable Disconnection and Connection (Refer To List 1) in Engine Electrical.
Remove the throttle body air inlet duct.
Drain the coolant from the cooling system. Refer to Cooling System Draining and Filling (Refer To List 2) in Engine Cooling.
Remove the inlet radiator hose from the engine. Refer to Radiator Inlet Hose Replacement (Refer To List 3) in Engine Cooling.
Remove the thermostat bypass pipe. Refer to Thermostat Bypass Pipes Replacement in Engine Cooling.
Remove the exhaust crossover heat shield bolts.
Remove the exhaust crossover heat shield.
  1. Remove the exhaust crossover pipe studs/nuts.
  2. Remove the exhaust crossover pipe.
end , remove.
now the bypass pipe FWD cars SUCK
  1. Disconnect the left engine mount strut from the engine.
  2. Remove the heater hose from the bypass pipe.
  3. Remove the thermostat bypass pipe to throttle body nut.
  4. Use the J 38185 in order to remove the thermostat bypass pipe hose clamps (1,5).
  5. Remove the thermostat bypass pipe to cylinder head nut (3).
  6. Remove the thermostat bypass pipe bolt (4).
  7. Remove the thermostat bypass pipe hose.
  8. Remove the thermostat bypass pipe.
sigh.....
why not log in to alldata.com
read the page then ask ques tons that are not clear.
and next time post the engine type.
above is just 1 engine.
Jun 18, 2014 | Cars & Trucks
Bypass thermostat
Bypassing the thermostat on a water heater is not adviseable. It may burst and do unforeseeable damage and injury.
Jan 13, 2014 | Whirlpool Water Heaters
My thermostat has quit working and we need to bypass it until we can get a now one. How do we bypass the thermostat?
if 2 wire just put to gather problem is then u become the thermostat and have to remove the wires from each other to turn it off or it will burn up the funice
Dec 11, 2013 | Heating & Cooling
What is refrigerant charge for ge pcsc5vgxafss s x s refrg
sorry for me being so brunt but if it something you have to ask it is something you should never attempt
Jul 21, 2011 | Refrigerators
My dometic refrigerator unit is not cooling properly on gas or electric. The freezer gets cool but the fridge stays warm. What could cause this?
my domestic refrg will not work on electric but will lite on gas. freezer will get cold on gas but bottom will not cool.you can plug refrg in and it will kick the gas off. you unplug refrg on gas will lite.that part of the power board seems to be working.
Apr 17, 2011 | Dometic RM2652 Refrigerator
Have a kenmore model # 110.72822101, where's the thermostat located, my dryer gets hot then cold
The cycling thermostat or the high-limit thermostat may not be the problem but rather the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify this condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Note: This is an image of an electric dryer but the thermostat and the thermal cut-off (cut-out) locations are the same.
Disconnect each of the thermostat wires then connect and insulate them properly. Once done, reconnect power and start the dryer. The gas valve solenoid coils are indeed faulty and both need to be replaced if the problem still persists. Click here for the procedure in replacing the solenoid coils.
Gas Valve Solenoid Coils Replacement Procedure
Either or both of the cycling thermostat and the high-limit thermostat are malfunctioning if the dryer continues to heat up with the thermostats bypassed. Disconnect power then reconnect the cycling thermostat wires but keeping the high-limit thermostat bypassed. Reconnect power then start the dryer. The high-limit thermostat is the culprit if the dryer continues to heat up. If not, then the cycling thermostat is the culprit.
Also do the other way; that is reconnecting the high-limit thermostat wires but keeping the cycling thermostat bypassed. The cycling thermostat is the culprit if the dryer continues to heat up. If not, then the high-limit thermostat is the culprit.
Replace the faulty thermostat and it should solve the problem.
Nov 08, 2010 | Kenmore 72822Gas Dryer
Hi The old thermostat broke down and the AC technician bypassed the thermostat on our external Brivis Buffalo. I have a new programmible Honeywell Pro 8000 Thermostat, however when the electrician...
Well, how did he bypass the thermostat? Is it just a wire? First turn off the power to the unit and then simply remove the bypass by cutting it out or unscrewing it. I'm not exactly sure what he did, but if you take a picture and post it here of the bypass (as you can bypass something different ways) then I can tell you what to do.
If you are unable to post a picture here, email it to me at bestdarntootingood@yahoo.com
Let me know how this works out for you.
Benjamin
May 25, 2010 | Heating & Cooling
I think the wire on my refrg. is wrong because when I put the new switch on the come on when the door is closed and cut off when the is open. I think that I have some wire wrong do anyone have a wire...
Do you have an ohm meter or knowledgeable about 1 . Radio shack have inexpensive ones . It will take one to help you resolve your problem .
Jul 18, 2009 | Refrigerators
U-Line ?chelon 2175RB-00 Logo
88 people viewed this question
Top U-Line Refrigerators Experts
Elie Balas
Marvin
Marvin
brokenrubber
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
