This has already been posted on Fixya, so I take no credit for it. I've put the original reply below :-
Directions for setting the time on the adidas duramo / furano / uraha / paruko watch 1. press and hold the SET/LIGHT button (upper left) until "light on" or "light off" is displayed 2. press the MODE button (lower left) until "hour" is displayed and the hour digits are flashing 3. use the START/STOP (upper right) button to increase the hour, and use the LAP/RESET (lower right) button to decrease the hour 4. press the MODE (lower left) button again and "minute" is displayed and the minute digits are flashing 5. use the START/STOP (upper right) button to increase the minute, and use the LAP/RESET (lower right) button to decrease the minute 6. press the MODE (lower left) button again and "second" is displayed and the second digits are flashing 7. use the START/STOP (upper right) button or the LAP/RESET (lower right) button to set the seconds to "00" 8. press the SET/LIGHT (upper left) button to accept the changes
Their web site is not very helpful on instructions, so I suggest you go there http://www.breitling.com/ and click on "service centers" to locate your nearest, and ask them for advice (and a set of instructions perhaps).
Not good news.The parts are only available from Breitling and this will require the watch is sent to them.There is probably a fault on the circuit,if its out of any guarantee this will be costly.There is a UK Breitling repair centre try Breitling.com or find a good stockist.
Regards
QUICKSTART - SET THE TIME 1. Push the bottom right hand button until the mode hand indicator points to TME. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Select the time zone on the digital display by pressing the upper right button or the lower left button. 4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time. 5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00. 6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time. 7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time. 8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour. 9. Push the lower right button back in.
SET THE CALENDAR 1. Push the bottom right hand button until the mode hand indicator points to CAL. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Select the time zone on the digital display by pressing the upper right button or the lower left button. 4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month. 5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date. 6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year. 7. Push the lower right button back in.
SET THE ALARMS 1. Push the bottom right hand button until the mode hand indicator points to AL1, AL2 or AL3. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Select the time zone on the digital display by pressing the upper right button or the lower left button. 4. Pull the lower right button out one click. You will see ON or OF flashing on the digital display. Press the lower left button to turn the alarm on or off. 5. Press the upper right button. You will see the hours flashing. Press the lower left button to change the hour. 6. Press the upper right button. You will see the minutes flashing. Press the lower left button to change the minutes. 7. Push the lower right button back in.
SET THE TIMEZONE 1. Setting the time zones allows you to add or remove cities on the digital display or switch between daylight saving and standard time. Begin by pressing the lower right button to move the mode hand indicator to SET mode on the bottom dial. 2. If the hour or minute hands are obscuring the digital display, press and hold the upper left button for three seconds. This will cause the hour and minute hand to retract to the 12 O’clock position. 3. Now pull the lower right button out one click. You will see the digital display flashing. Press the upper left button to select SET to display the city or OFF to not display the city. Press the lower left button to turn summer time on or off. Summer time is indicated on the lower part of the digital display. Daylight savings time must be manually set for each city. 4. Pressing the upper right button will allow you to scroll through all the cities. After setting, push the lower right button back in.
USING THE TIMER 1. Press the lower right button to move the mode hand indicator to TMR mode on the mode dial. 2. If the hour or minute hands are obscuring the digital display, press and hold the upper left button for three seconds. This will cause the hour and minute hand to retract to the 12 O’clock position. 3. Pull the lower right button out one click. You will see the minutes flashing in the digital display. Change the minutes by pressing the lower left button. Once you have set the minutes on the timer, push the lower right button back in. 4. Pressing the upper right button starts and stops the timer. 5. Press the lower left button when the timer is stopped to reset the timer to its initial preset time.
USING THE CHRONOGRAPH 1. To use the chronograph press the lower right button to move the mode indicator hand to CHR mode on the mode dial. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3 .To start or stop the chronograph press the upper right button. If you press the lower left button it will display the split time for 10 seconds. 4. When the chronograph is stopped press the lower left button to reset back to zero.
SET THE TIME ZONE 1. Setting the time zones allows you to add or remove cities on the digital display or switch between daylight saving and standard time. Begin by pressing the lower right button to move the mode indicator hand to SET mode on the bottom dial. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Pull the lower right button out one click. You will see the digital display flashing. Press the upper left button to select SET to display the city or OFF to not display the city. Press the lower left button to turn summer time on or off. Summer time is indicated on the lower part of the digital display. Daylight savings time must be manually set for each city.. 4. Pressing the upper right button will allow you to scroll through all the cities. After setting, Push the lower right button back in one click.
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
1. Push the bottom right hand button until the mode hand indicator points to TME. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Select the time zone on the digital display by pressing the upper right button or the lower left button. 4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time. 5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00. 6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time. 7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time. 8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour. 9. Push the lower right button back in. SET THE CALENDAR--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Press MODE (lower left) button until "ALARM" appears in the display. Then press SET (lower right) button. T1 should flash to indicate you are setting an alarm for Time 1. Press MODE to cycle through the alarm settings. Press ALARM (upper right) button to advance the hours, tens and minutes to the desired time. When the far right of the display is alternately flashing "T1" and then "AL" you can change the chime and alarm tones by pressing the ALARM (upper right) button. The alarm is on if the middle symbol (lines) on the left of the display is shown. The hourly chime is on if the lower symbol (bell) on the left of the display is shown. When you are done, hit MODE (lower left) again to return to normal time display.
