There is power to the EPSON L200 PRINTER but it will not turn on. No power.
Make sure all leads connecting to your printer have dust free secure seating
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver disable uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope it helps
Your sulotion didn't help at all... I the solution were you change many power cable that are working in other printer but in may printer it will not power on...
I can only go on the information given your english may be a little hard to understand or you are learning it
I have the same problem with my Epson L200. I already check the main power supply voltage output and it's normal. I beleive that the problem is in the main system board. When I plug the printers power cord and ress the power button it will not power ON. toally dead set.
check for the obvious which you probably have have a look at the event viewer Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER look for anything related to your printer you might be able work your way through the problem
same problem with benjie and i looked the event manager it says print spooler failed to load a plug in module? what is the meaning of that?
no lee light no power
1st checked the power sours is OK
2nd pull out from the power extinction & put directly in wall socket
3rd open the cover check the power supply on board if u have multi meter.
