Whie trying the system reset (i.e. wiping out all prigrammes and rebboting afresh) the rebooting stooped after about 93% booting with the message NTLDR Missing . Now the computer does not boot. It does not have a CD drive . HOW to correct thge problem to get the computer booted properly?
USB cd-rom's are pretty inexpensive. Here's a page of examples:
https://www.amazon.com/Best-Sellers-Electronics-External-CD-Drives/zgbs/electronics/1292121011
Or you could put a Hirens boot disk on a USB thumb drive and run it. There are articles how to repair that error message. Do a Google search for "NTLDR Missing".
SOURCE: not booting from cd
may be the boot priority had been incongruent ...... so set the cd rom as the first priority . then try to boot from the cd rom... thank u sir
SOURCE: ntldr is missing, this information is regularly coming even thoug
1. You must have a copy of "ntldrusb.zip" file.
USB: Right click the ntldrusb.zip file and choose "Extract All" Next>Next>FinishThen Insert your USB Stick into the working computer (remove any other USB sticks, and be sure there isn't anything on the USB stick that you want since we are about to erase it);
Double-click HPUSBFW.EXE in the ntldrusb folder;
Check "Create a DOS startup disk" and "using DOS system files located at" then press the grey button with the "...";
A box will come up asking you which folder to select, point it to the "dos system files" folder;
Press OK; Press Start; Press Yes; Let it run for just a few minutes till a new box comes up; Press OK; Press Close;
Open the "putonusb" folder, copy all the files, paste them onto the usb stick (just in the root of the drive, like E:\);
Eject the USB Stick; Remove it from your computer;
Place it into the computer with the "NTLDR is missing" issue, reboot it.
You will see the Windows 98 screen pop up for a second, then you will see a black screen with white letters prompting you to "replace boot sector of the drive C: (y/n)", press the y key;
It will go to a C:\ prompt, reboot the computer by pressing Ctrl+Alt+Del; (now go to step 4)
4. Put the new floppy/cd-r/usb you have just created into the computer that gets the NTLDR is missing error message, turn the broken computer off.
4. Put the new usb you have just created into the computer that gets the NTLDR is missing error message, turn the broken computer off.
f you get back into Windows again, you can change that "1st Try This" menu by going into Start > Control Panel > PerformanceAndMaintenance/System > Advanced tab > Startup and Recovery section, Settings button > System Startup; then change the "Default Operating System:" to the selection that worked for you, and change the box that says "Time to display list of operating systems" to however many seconds you want (usually 1 second). Click OK twice.
SOURCE: acer 5515 backlight not working also bootmanager missing
You need to fix the boot manager problem first by connecting an external monitor to the laptop so you can see and do a system repair.
As for the backlight problem :-
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info
SOURCE: Acer aspire one mini notebook. NTLDR is missing..
If you don't have documents, pictures,
etc on the hard drive that you need to backup, try running system
recovery by doing the following (not sure if this works on the version
with a solid state drive):
1. Turn on the computer
2. Press and hold Alt + F10
3. Click on Restore System to Factory Default
4. Ensure the netbook is plugged into AC power instead of running off the battery and click OK
* This will return your netbook to the condition it was in from the manufacturer.
