Will full lamp block hitachi number ux21513 fix yellow to green tent that appears on all viewed channels? And/or is their more parts I need to look purchase?
You have some reason to believe it will not?
Some history for you---several years ago Hitachi began along with others to have issues with the optical light engines.
With a mix of high heat from a lamp into the engine (it has a blue,green and red section inside---guess what? BLUE is the first place that gets the heat and is damaged----minus blue and you have red and green which equals YELLOW.
Several of their sets made about 6 years ago (research 50v500) had exact same issues and were settled in a class action lawsuit.
The issue can but does not always affect the entire screen.
The question really is: This set really worth the part and labor cost for the repair?
On that earlier model I replaced under warranty over 40 of the engines. Also Sony and others have had similar issues some of which were settled in court.
HOPE IT WORKS OUT FOR YOU.
SOURCE: I have a hitachi DLP TV modle no ux21513
Lamp with housing is a LM500
But to save a few dollars call Glen at ACME Sales in Florida for the best price on just the bulb and put that in the new housing. It's about half the money.
1-800-575-9833
Bill
SOURCE: Have yellow spot in center of screeen
it is actually a light engine problem, i have replaced probabily 50 of thease for that exact problem, it is a prity hard part to change yourself, and it costs about 400 dollars
SOURCE: grenn yellow tent
the color filters are burned from heat there are three small glass filters one is red one is blue and one s green They are in the light engine.I know I have the same tv and the same problem.you have to take the light engine apart or you could replace the light engine.a lot of plugs and screws to take out just to change three colored glass plates
