Cooktops Logo
Posted on Nov 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my jenn gas cook top burners all flicker when turned off
I have jenn air gas cook top stove that won't stop flickering turned off
gerbee gomez
Level 2:
Novelist:
  • Expert 222 Answers
  • Posted on Dec 02, 2008
gerbee gomez
Expert
Level 2:
Novelist:
Answers
222
Questions
0
Helped
139299
Points
388
Hi im gerbee,i will sujest to clean the area were is the place of ur knob control try to remove the control knob then clean it by using a vaccium coz sometimes the problem is very dirt of the control knob.
. Burners will not work unless the down draft fan is turned on and then neither works at full capacity.I flipped the breaker off and on.
Call Jenn-Aire to have a technician troubleshoot your cook top on site. You will save time and aggravation whether your cook top is gas or electric, possibly wired improperly, etc,etc,etc.
4helpful
My stove top now keeps clicking, even when it is
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Constant heat not produced on Jenn Air Schott Ceran stove top
It's a piece of ****, replace it the first chance you get.
1 burner flares and sputters
Hello. Chances are that something on the stove boiled over or got poured into that burner. take it off, soak it overnight in water with dishsoap added, then rinse it and let it dry before reinstalling it. Repeat the soaking in soapy water if necessary until the flaring, sputtering and black soot is gone. regards, Joe
All cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
3answers
Spot on Jenn Air smooth cook top stove with down draft.
Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
Gas cook top
thanks for the question yes some stoves do this and its normal when the burner you selected lights turn to low or hi the igniter will stop they do this to save on igniter modules thanks the appliance doc
2answers
Jenn-Air electric stove top - burners/fan won't come on
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Stove top [gas] JENNAIR
Try carefully cleaning around the ignitors. Also clean hole in burners. Clean the holes closest to ignitors. This can be caused by a crack in ignitor, this requires replacement.
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
