1709,1778. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/
Type in the brand name only of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
This question does beg for more details. For instance, some HDTVs have an optical out which can be hooked into the Denon. This works great when the unit doesn't have HDMI I/O. I have one such Denon unit [1312] which I bought for that exact purpose. It's all I could afford, and it works. You do have to have the rcvr set on TV or whatever the optical in goes to.
Or, some people have a newer Denon and setup their RCVR to switch and only one TV input from the RCVR. then it's the cable box connection you need to check/switch to. it's not simple, but it's not that hard either. I you need more help you can PM me.
There are so many brand universal remote controls, which have setup codes to Denon. The common setup codes to check with Denon Brand Audio devices are, 0481,0482,0038,0031. If
you wish to buy its original remote control, you have to contact the authorized
service center. If you wish to buy a
universal remote control, you should know about, which brand remote control
have setup code to your TV/device brand. You should first make sure about the
number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You
can get this detail by the code list attached to every universal remote
control. The brand name of the remote
control you select isn't a matter; but, its code list should have setup codes
to your TV/device brand, otherwise you can't set it up with your device. Check out, which brand remote control has
setup codes to your TV/Device brand.
Setup code list & setup procedure to some popular brand remote
controls are given. Check it, and
determine which brand remote control should be bought, and buy that brand
remote control, according to availability. for more information go to http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
If the Denon remote control have setup code to WDTV, you can. If you wish to get more details, check the
links given below. Setup code list and setup proceedings to many popular brand
remote controls are given. Pull up older posts there. You can also make a
search by type in the brand name of your device into the search box; can be
located at the top right of the display window. More than Nine Lakh viewers
cannot be wrong. http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
You need to use the monitor output on the denon and go to a video input on your tv, be sure the tv is set to the video input you plugged into on the tv input, then take the denon remote and hit the setup button, should show a on-screen setup
