As you're facing the rear of the unit, you will see a drain hose connection with a drain cap in place, don near floor level. Using a garden hose, no longer than 5 feet, remove the drain cap and save for future uses. Connect the garden hose section to the drain hose connection. Roll the dehumidifier to within 5 feet of a floor drain and place the hose at the inner edge of the floor drain. Be use the hose is sloped down and without bends or kinks. Plug the dehumidifier in, turn it ON and set the humidity extraction level at 35 - 40%. Monitor the hose to make sure its draining after 15 minutes of operation.
Keep in mind, the drain hose relies entirely on gravity to drain. It will not drain, if the hose is not sloped it's entire length down from the unit.
To assist you further, I have included a link to your Owner's Manual, that you can download and print for future reference.
http://www.danby.com/cms/uploads/products/en_manual/DDR586R%20EFOM.pdfI hope this helped you and thanks for choosing FixYa.
