LG DH30 GoldStar Dehumidifier Logo
l. koliani Posted on Jun 08, 2012
Want to download manual for lhd30 - LG DH30 GoldStar Dehumidifier
Looking for the manual foe a garrison dehumidifier model 043-5434-6 it doesn't seem to be dehumidifying any more
You can find the manual for the Garrison dehumidifier model 043-5434-6 by visiting the manufacturer's website or by searching for it online. Here are the steps to find the manual online:
  1. Open your web browser and go to the Google search engine.
  2. Type "Garrison dehumidifier model 043-5434-6 manual" in the search bar and hit enter.
  3. Several websites will appear in the search results. Look for a website that offers the manual for download or viewing.
  4. Click on the link to download or view the manual.
If you are still having trouble with your dehumidifier even after consulting the manual, you may want to consider contacting the manufacturer for assistance or bringing the unit to a professional for repair.
3helpful
Lg dehumidifier lhd30 normally removes an almost full bucket of water from my basement every 24 hours. Now in July it stopped doing so. I get about an inch of water per day now. If i turn the control down...
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1& 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a mechanical unit,
uni, set the control knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor may have failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you to troubleshoot & solve the problem.
I was looking for a manual to download, the fan is bad and I need a parts list. The download on the manual section did not work
Fedders made that unit for Maytag. Check the Fedders website for the same model number (just drop the M off the front of the model number) and you should be able to find what you need.
I have a HD456E that I purchased at Menards about 2 years ago. It's worked fine until a few days ago. It is running but, not a drop of water is in the pan. What do I need to do? I have misplaced my...
Hello friend, I may be of help after all in locating a user/service manual for your hair HD456E dehumidifier.
Check the link below and download the specific manual.
Hope this helps https://haier.encompass.com/shop/model_research_docs/?file=/HAI/om/HD656E.pdf
Even though you'd notice the link reads at the end hd656e.PDF, go ahead and download it. Same manual applies. *smiles*
It is specified on the user manual HD456E
3helpful
3answers
LG LHD30 the compressor does not cycle on
Compressor won’t Start
The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Lg LHD30 dehumidifier not producing water; fan and compressor both seem to be working
there may be no moisture to collect in the air. if you turn up the dial and the compressor kicks in, all is fine
2answers
Dehumidifier will not shut off
The auto shut off will work when you have your bucket in, as well when you have met the humidy level which you have chosen. Try changing the setting.
Sgt 48
7helpful
Delonghi de 220 dehumidifier tasciugo
http://www.manualnguide.com/download/manual-guide/
delonghi-de500p-dehumidifier-owners-manual.html
The above URL will allow you to download instruction manual if a PDF format.
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
