Indesit W 123 Front Load Washer Logo
A
Anonymous Posted on Dec 23, 2017
All of the lights on my Indesit WIL123S washing machine are flashing. All the repair people that I ring tell me I need to replace the circuit board but I believe the capacitor is broken because the x-mark on the capacitor is gone. Am I right??? If so I just need to replace the capacitor? Cannot afford new PCB!!
Eric Taylor
Level 3:
Master:
  • Master 590 Answers
  • Posted on Dec 27, 2017
Eric Taylor
Master
Level 3:
Master:
Answers
590
Questions
6
Helped
205904
Points
1556
How would you tell if what capacitor is faulty on the board I would rather seek out a college who is perhaps more used to testing such items as the AC mains is lethal and I would not want to give you any reason to injure your self please be careful eric
5 Related Answers
Anonymous
  • 247 Answers
  • Posted on May 07, 2007
SOURCE: washing machine blown fuses
Can't promise it isn't the motor, but there are other suspects (maybe more likely, and probably cheaper to fix). Few questions: 1. Do you have a RCCB (also called an RCD, Residual Current Device, Current Operated Earth Leakage Trip etc.) protecting your ring mains? (How to look for one: If your wiring is less than fifteen or so years old, it might be built into the main switch on your fuse box, if a little bit older, you want to look for a separate box - usually grey, about the shape and size of an After-Eights box, with a big switch and a test button on). 2. What stage of the cycle does this happen at? 3. If it always happens during the "wash" phase, can you make it happen at all if you run a series of cold wash cycles? (don't need to have laundry or detergent in the machine to test this). A.
Anonymous
  • Posted on Feb 27, 2008
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
douglas smith
  • 1462 Answers
  • Posted on Jun 25, 2008
SOURCE: Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Howard Galley
  • 197 Answers
  • Posted on May 09, 2009
SOURCE: lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
Anonymous
  • 1922 Answers
  • Posted on Oct 19, 2009
SOURCE: replace broken drum paddle
remove front and then top cvrs and you can repl paddle from there
When I on the machine LG WF-F5700PCX ,all the lights are blinking. water is not flowing in.
Washing machine all the lights flashing, error codes on ...
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - In this video I'll be showing how to fix a washing machine with all the lights flashing and how to identify error codes or fault codes on Hotpoint, ...
Washing machine lights flashing - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - Flashing lights Many modern washing machines display error codes if they detect a fault, but they don't all display a readable error code.
Flashing Lights on Washing Machine How to Repair ...
? 8:05
https://www.youtube.com/watch?v=P6WZNLO6wE4
Oct 22, 2014 - Uploaded by how-2-repair.com
Flashing Lights on Washing Machine How to Repair Hotpoint, Ariston, ... flashing like this.error faults are available at our website for all makes.
Indesit Washing Machine Repair: Flickering Or Flashing Lights
? 4:36
https://www.youtube.com/watch?v=S1L2N7srXKs
Mar 27, 2014 - Uploaded by DextersLab2013
Indesit Washing Machine Repair: Flickering Or Flashing Lights... Since making this video i have had to replace all of the remaining capacitors ...
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Blinking lights
? 8:05
http://www.how-to-repair.com We are working on a tvm570 but this is usually the fault with most boards ...
? 4:36
In this video i remove the Computime control board on an Indesit WIXL163S washing machine where the front ...
1helpful
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Not working
when lights flash on indesit washing machine means there is a fault with the machine you will need to tell me which ones are flasing so i can tell you what the fault is
6helpful
Lights flashing on indesit WIL123S
and replace.
1helpful
Selector knob on my Indesit Washing Machine WI 121 keeps turning & light flashes twice before light turns off. This happens approx 4 times in a whole turn of the knob. Indesit want £100 to come out to fix!...
Hi.
Sounds like you have faulty control module, which is quite expensive to replace.
Also the E.P.R.O.M would have to be replaced as well.
Probably cheaper to buy new washer.
Good luck.
Top Indesit Washing Machines Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Sean Wright
Sean Wright
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
