SOURCE: Need instruction manual for the
I borrowed one of these and got most of the job done.
Here's what I ended up doing:
At a site with good drainage, a little uphill, stake down the floor of the tent
Longest two poles go through the twin sleeves in the center/top. They are color coded red and yellow
These two poles are anchored at the base by the center color coded ring_peg
The tube ends of the fiberglass poles. Fit over these pegs.
The slightly shprter fiberglass poles go trhough the two blue sleeves.
These poles get anchored on one end by a yellow ring peg and on the other by a red ring peg. They hold the vented windows up.
The arch shaped pole is threaded through a black sleeve atop the entrance to the. Tent.
The arch is anchored on either side by a red ring peg on one end and a yellow peg on the other.
Stake the lines from the screen windows outwards from the tent
Spread the tarp over the top and stake the corners to shelter the screened top from rain
Remove the tent and poles from the packaging. Select an indoor area with a high ceiling or an outdoor area without overhead obstacles. The poles are not excessively long but they will be difficult to assemble without space.
Lay the Princess tent with the floor on the ground. Pull on each corner to tighten the floor. Assemble the two tent poles by inserting the male sections into the metal ferrules.
Slide one pole through each of the diagonal sleeves. Place the end of each pole in the fabric pockets on the corners. This will flex the poles and raise the tent body.
Place the fabric roof on top of the tent. Attach the hooks on each corner of the roof to the loops on the top of the pole sleeves. The roof fabric will stretch tight and cover the ventilation gap in the tent ceiling.
