Televison & Video Logo
Anonymous Posted on Jun 06, 2012
Onkyu DR-S2.0 will nit read cd or dvd
Anonymous
Level 3:
  • Master 1,961 Answers
  • Posted on Jun 07, 2012
Anonymous
Master
Level 3:
Answers
1961
Questions
Helped
665768
Points
5692
Hi, failure to read disk means that the needs cleaning or replacement but before replacing we need to try first to clean the lens manually..
you need to open the top cover of the player by removing the screws.The lens is situated right at the center of the CD mechanical loading system...It is like a small crystal that focus on the CD...use a cotton buds moistened with an alcohol (rubbing alcohol) gently wipe it on the lens top to remove dust accumulation..let it dry then try to play the CD.. consider also the CD format you are using make sure that they are compatible with player.....thank you and good luck let me know if you need further assistance..
Does the JVC DR-MV5S DVD recorder/VCR combo unit have an analog tuner or digital tuner, so that you can record one channel while watching a different channel on your TV?
You can read what JVC is telling about the recorder. It is not an digital tuner, but still you can record a DVD and watch another channel or vice versa.
Want to read the whole manual? click the link:
DVD Recorder Hi Fi VHS Combination DR MV5S Introduction
tip
Well, My JVC DR MV1s is reading and records my DVD-R but it stop reading and...
The most common mechanical problems that can prevent a dvd player from playing or reading the discs are the following:
1. The spindle motor not functioning properly (this is by far the most common, if the spindle motor is not spinning the discs then the optical lens can not read them). For the most part it is an cheap part to replace averaging around 25-35 dollars if you can replace it yourself. If you do not know how and have to take it to a repair shop expect to pay 50-75 dollars in labor depending on the area you live in. The best thing is to do some comparison shopping and call the different repair shops and get estimates. The key is to listen closely when you insert the disk into the player, you should be able to hear it spin up. If you hear nothing then that is most likely the problem.
2. The tray could be out of alignment. This is another easy and cheap fix if you have the proper tools. This could happen if you drop or pull/push to hard on the tray (which you should not really do anyway, but always use the open and close button). This is an example picture of the drive assembly with the tray open.
3. The small gears are plastic and often break, this will cause the players other parts to not move and function properly. They are difficult to reach, but inexpensive to replace. It is always recommended that you always order any part from the manufacturer of the device. A visual inspection is usually required to determine if the small teeth have been broken, which requires for the most part taking out the carriage assembly.
4. The small belt drives either break or come off. Again, this will cause the other mechanical parts not to function. They are difficult to put back on as well, so you may need an extra pair of hands if you have not done this before. On average you will usually have 2-3 of them inside your player.
5. The Optical reader has malfunctioned. This is the most expensive thing to replace, so you might consider purchasing another player depending on how much you want to spend and the original cost of the device, unless you can find a great deal on the part you need. You can check to see if the laser is firing with a visual inspection (DO NOT LOOK DIRECTLY INTO THE LASER) put in a disc with the case off and you should see the glow of the laser hitting the disc. You can also see the spindle/spindle motor.
Picture of the optical reading assembly dismantled:
6. The tray also has a drive motor which can fail and cause the cd tray not to open and it also has a track that it rides on (located in the drive assembly). Check these two components if you are having problems with your tray not opening and closing properly or stops working completely. Sometimes, the tray will open and then immediately close on it's own. This is usually caused by the track being dirty or some type of debris is lodged in the track. Cleaning the inside of the player with a can of compressed air will help remove dust and dirt. Blowing out the inside of the device once a month is a good preventative maintenance measure.
CAUTION: When working with any electrical device, you should always ensure safety first. Make sure that the device is turned off and unplugged from any power source. This does not completely prevent electrical shocks because Capacitors will hold an electrical charge for some time even if the device is turned off and unplugged.
The following are example pictures of what Capacitors look like:
Jvc dr-mv100 won't eject dvd and doesn't sound like it's trying
Check and replace the CD loader mechanism. It is faulty. Do not loads CD onto reading deck properly.
Can play cd but not dvd
You may have just a dvd player only.However if the front of the drive has a Dvd rom symbol and will not play Dvd. You might as well Replace the drive.
Good luck
Get "read error " when a standard DVD is put into a Panasonic DR
if it don't read cd's either then you won't be able to use a cd lens cleaning disc and then you will have to manualy clean the lens on the laser inside , because it is then to blind to read
Reading a DVD.
Try finalizing the disc with your PC using Dr. Divx or another finalizing program, and see if it will work in your DVD player. If that fails, then the DVD was burned in a format that the Toshiba will not recognize.
1helpful
Dvd player combo
uncompatable disk?if not try cleaning the lens of the player by using a cd/dvd lens cleaner...the cd thing with the two brushes stuck onto it...with some cleaning fluid
JVC DR-MH30S DVD Recorder Image file
ciao! tutti vittime del dvd rec [jvc dr mh20-]..jvc dr mh 30...jvc dr mh 50..e un risolvere dell problema di LOADING...il mio jvc dr mh30..di 6 mese e roto ..ma trovo risolvere..difetto e nel hdd,160gb..e in corrozione..e roto hardisk,solo sistema operativo.......con softer COPY CLONE PRO..free da iternet.scarica nell cd room..nel avvio dell pc,che sono due hdd,uno rotto ,e uno buono..guarda instruzione dell cd..e tutto ok,per copy di hdd..e tutto ok per legare poi nell dvd rec jvc dr mh 30..ho provato io e tutto ok...ma io ho trovato hdd dell dvd rec jvc dr mh20..e io ho un dvd rec jvc dr30..ce un problema picollo dopo copy cloner,,mio dvd rec mi conosci solo 80gb..ma perche e in origine da dvd rec jvc dr mh20[80gb]..cercho un hdd di dvd rec drm h30..opure jvc dr mh50..per copy cloner,mio hdd,per conosciere 160gb..opure 250gb..atentti problema di LOADING..e nell due alimenti di hdd..e suporte di dvd..sono quattro line..12v..terra..terra..5v....sono simille anche perhdd..anche per suporte dvd..controla nel condizione di LOADING..se non sono precise..voltaggio..persempio..12v=10v..opure 5v....4.2v..e perdita..da un contesatore electrolitica.e asciugato da lavoro fastidiosa.......se aiuto da poco..non lo so aspettiamo nell mio e-mail....arivederci[ [email protected] ]
JVC DR-MV7
Why are you using a CD-R? You need to use a DVD-R! Or DVD+R.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
